F100 front Dana 44 fit rear??
Hi, Another general purpose question. Ripped a 1976-1980 F100 4X4 FRONT end apart for the brake set up and whilst I was at it, took the Dana 44 3.5:1 Crown wheel and pinion, in excellent nick. Have a LSD Dana 44 REAR here as well with a few noises, 3.73:1 so was wondering if the Ford front CW & P will fit into the rear 44? Believe it is NOT the HP version, anyway of telling by the Dana numbers stamped on the rim of the crown wheel? Not having a great deal of luck with Dana numbers for some reason, maybe not asking in the right forum section?? BTW, using it in 2WD vehicle!
Cheers, Dave 64
Cheers, Dave 64
Dave, this page has a lot of useful info: Mr.N's Dana Articles to Include 44, 60 information.
Specifically this page: Dana 44 Solid Front Axle: Reverse Spiral and Standard Housing info..
The front D44 should be a High Pinion one. All F100 front axles from 1966+ had D44HP's to my knowledge. This means that the pinion and ring gear are cut in the opposite direction and aren't transferable to the rear axle.
medino03
01-03-2012 06:02 AM
grey77
05-27-2004 10:39 AM
