1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
1962 F-100 Unibody Disc Brake Conversion
Old 02-12-2014, 10:47 PM
62integral's Avatar
62integral
62integral is offline
Im looking to buy the conversion kit from speedway motors...
Deluxe Disc Brake Kits: 1957-1964 Ford Half Ton - Speedway Motors, America's Oldest Speed Shop
Has anyone had any experience with this kit and how well it installs?
Should I be installing a proportioning valve, double master cylinder and booster? If so would I be able to pull a booster from a 65 f100? What could I pull the proportioning valve and/or master cylinder off of or buy new?
Thanks!!!!
Old 02-15-2014, 05:43 PM
William's Avatar
William
William is offline
Save your money. Drum brakes are as good as disk when used on a street driven truck. Ain't no advantage unless you race this thing or haul a lot. One improvement that won't cost a fortune and will provide real safety is a dual chamber master cylinder set up. If you have a few extra bucks add a booster. Power drum/drum brakes have been used successfully for decades and will provide good service for the money. Check out Master Power Brake for some good options. Spend your money on King Pins and bushings, spring shackles and a front end alignment. IMHO.
Old 02-08-2015, 04:37 PM
Koolkat's Avatar
Koolkat
Koolkat is offline
disc swap
I performed the Speedway disc swap on my '62 and it is awesome! Easy to install and you don't need a booster. If you didn't do it yet you should. You cannot source the parts out any less expensive. Use a Master cylinder for a early '70's F150 and a block for a chevy truck, you can get them (the block) from Jegs for about a $50. Have fun! If you have the stock inne wheels, you can either use a 1/2" spacer to clear the calipers or remove the rivets holding the wheels together, remove the center of the wheel and reinstall it backwards, weld the wheel back together and then they will clear the calipers without the use of a spacer.
Mbellon
03-09-2014 09:48 PM
SeaBeeCm1
06-11-2011 08:23 PM
theodore/teddy
10-19-2010 03:09 AM
angus
02-23-2003 05:04 PM
darkman
10-29-2001 09:02 AM
Quick Reply: 1962 F-100 Unibody Disc Brake Conversion
