no crank no start help tried everything
i cant really post on the forum cant find my problem anywhere its a 2000 expedition 5.4L i replaced the battery, the starter, and the solenoid, i can turn the engine over by hand, and when i turn the key the starter clanks against the flywheel but wont turn over all the fuses are good and im completely out of idea's it started one day then bam hasn't cranked in 2 months
no start
Check connections on positive and negative battery cables at battery, block and starter. Test voltage across battery terminals when trying to start
if it stays above 10 volts check it at the starter between the positive
cable terminal and a clean ground like the starter case or the block.
If it's 10 volts or greater suspect the starter if not it could be the battery.
Try jumpers or charge the battery.
