2015 F150 to be pre-fitted for snow plows?
Seems as though Ford is going to add a snow plow option on all packages of the 2015 F150. They must really have a heavy duty front suspension for a snow plow. This isn't all that surprising, they've been doing it for years for the Super Duty trucks. I'm wondering since it sounds as though it's going to be standard across the board if they are offering a much stronger suspension like what was offered on the F250LD/F150 7700. Or with the reduced weight of the cab if that they won't have to.
This 2015 Ford F-150 Is Ready to Plow Some Detroit Snow
I first saw the news on my facebook feed https://www.facebook.com/photo.php?f...type=1&theater
what do you guys think?
You'll note that it's sporting a BOSS plow. BOSS plows are installed so the frame absorbs the majority of the shock and jarring instead of the front suspension.
This is a brilliant move for Ford and it's long overdue. http://www.bossplow.com/
The SSV F150 has an upgraded 220A alternator and it's supposed to deliver 80% of that at idle, if memory serves. Maybe they made that alternator standard across the line?
The plow package is only available on 4x4 trucks with the 5.0L V8 in XL, XLT, or Lariat trim. It will, however, be available on all cab/bed configurations.
Apparently what they did is incorperate a "Plow Mode" button. It shuts off some non-essential electronics while plowing to ensure the EPAS system has enough power. Not sure what exactly that means, but that's what Ford is saying.
Maximum plow weight will be just over 450lbs, so you're talking a fairly light duty plow. Still better than what they've offered for the past few years though (i.e. nothing).
To be fair, a larger alternator would add more drag to the engine, something they specifically don't want to do. Hence the whole purpose of going to an EPAS system in the first place, as opposed to the old engine mounted hydraulic pump.
I also doubt a a larger alternator alone would solve the problem. You would need to support that with heavier wiring, another battery, etc. All this stuff would add weight, which is the opposite of what Ford is trying to do with the new truck. If they found they could have the exact same result with a button and some programming that's undoubtedly the way they're going to go.
From Ford, looks like you must have a 5.0 to plow.
All-New Ford F-150 Adds Tough New Snow Plow Prep Option Across All Cab Configurations | Ford Media Center
