Query on exhaust
Query on exhaust
Hi All,
There is a truck up my way that sounds really throaty. I bumped into him today and asked him what exhaust system he was running, he said he's not, he has just removed the muffler
Is this good or bad for the motor, I'm not technically minded so I'll just put the question out there
Cheers,
Patchy
Cheers,
Patchy
I tried it but it did my head in - too loud! I'm running a 4" turbo back system with 2 'Hurricane' mufflers now.
If you have the Ford Australia turbo downpipe fitted you could delete the muffler. Any good exhaust shop could do it - they just make up a 3.5 inch diameter 'muffler delete' pipe.
No adverse knock-on affects on the engine/turbo from this that I'm aware of - in fact it would be an improvement as your EGT should drop with the removal a slight restriction. The problem is that the main restriction is the FA 2.5 inch downpipe which sits between the 3.5in turbo outlet and the stock 3.5in exhaust!
Diesels don't run "closed loop" like petrol engines, so you can do whatever you like to the exhaust as soon as it leaves the engine and it won't know any difference (unless its a new diesel with DPF). As Simon mentioned, the more flow/larger the exhaust after the turbo the better.
On my 7.3, I had a 4" dump/straight pipe from the turbine housing that exited just behind the cab (before the rear wheels). It sounded mean, and I am pretty sure there was permanent hearing damage caused to anyone following me in a tunnel when I downshifted. I didn't find the noise annoying at normal cruise, but as soon as it got under load it was too loud for continuous use - I didn't do any towing, but long uphill stretches were a bit of a pain.
If you do any towing, I would definitely suggest a muffler - but even running it behind the rear wheels would help a lot.
So Ford Aust put a step down restrictor pipe straight off the back of the exhaust housing?
Wow - let me guess, these utes are slow to spool up and they suffer high EGT's, possibly even cracked exhaust housings or tip rubbed, over temped exhaust wheels?
The goal is to have a step up diameter pipe straight off the housing, this stops the exhaust gasses spinning and gets them flowing properly. So that 4 inch dump sounds good
Cheers,
Patchy
Looks like a picture of a tail pipe there, looking up from the ground, yep 100% pure Brazilian no doubt about it - you can tell cause there's no hair !
You have to work your way forward and check where the exhaust goes up past the footwell on the way to the turbo, that's where the Down Pipe lives. That is where you'll find the FA DP - a lot of welded pieces choking it down to 2.5"
So you have a twin system hanging off the back of your stock Brazilian tailpipe?
This picture shows the FA DP above the stock Brazilian tailpipe - the little strangle box is clearly visible.
Here is a picture of the MBRP 4" turbo back exhaust I bought of Clay and shipped over USAtoAUS. The pipe on the lower left is the muffler delete pipe (I wish I bought the muffler now).
The 4" DP ended up being very hard to fit and had to be dented into submission - so much so that I think I may have had a better result getting a 3.5" DP into a 4" exhaust.
The only hassel I seem to going to have is finding someone in Cairns willing to do the fit
Cheers,
Patchy
diesel-fitter-bum01
12-28-2010 09:39 PM
chaderiksn
20
10-26-2003 07:20 PM
