Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
Clunking/clanging on 02 mercury mountaineer
Old 01-08-2014, 06:59 AM
Oldmossy's Avatar
Oldmossy
Oldmossy is offline
Hello, I have an 02 mercury mountaineer awd. It's making a clunking/clanging sound when going in forward and reverse and it gets louder when turning. Just replaced driver cv axle, changed fluids on front and rear differential also put the stiction modifier in rear. It only does it on the ground assuming it's putting a load on it. Won't do it on a lift. Any ideas what might be causing it. Any info would be great. Tires are same size also.
Old 01-08-2014, 08:21 AM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
DId the clunking happen after you changed the axle ? If so, you have the CV in a bind during install. If it clunked before and after, i would look at the drive shaft universal joints, and maybe inside the rear brake hubs for damaged parking brake shoes.
Old 01-08-2014, 08:31 AM
Oldmossy's Avatar
Oldmossy
Oldmossy is offline
It did the noise before install of the cv axle. It almost sounded like that's what is was coming from so that's why I changed it. Brakes are all brand new rotors and pads. Checked wheel bearings they seem fine also. It will only do it under load, it won't do it on a lift. Mind boggling.
Old 01-08-2014, 06:18 PM
steve(ill)'s Avatar
steve(ill)
try to wiggle the drive shaft into the rear axle at the universal joint. See if you have excess play in the pinion bearing.
Newington
Modular V8 (4.6L, 5.4L)
07-16-2017 10:05 PM
3cv
1999 to 2016 Super Duty
18
03-27-2012 11:28 PM
slow3v
10-05-2011 07:38 PM
Wild Karrde
11-19-2006 12:36 PM
rjlucas
03-21-2006 10:01 AM
Quick Reply: Clunking/clanging on 02 mercury mountaineer
