purpose of bolt hole?
Old 12-03-2013, 10:12 AM
unibody62's Avatar
unibody62
unibody62 is offline
I guess I didn't take very good pictures when dismantling my 1962 292, because I can't find out what bolts into these holes in the heads.
empty - a set on Flickr
They are all the way to the back and not covered by the intake. For now, I just plugged them with short bolts, but I was thinking that at least one of them would be used for a ground wire. Is that correct, or is there another purpose?
Old 12-03-2013, 12:43 PM
Y-Blockhead's Avatar
Y-Blockhead
Y-Blockhead is offline
If you look at the heads they can be installed on either side. If you had swapped heads that bolt hole would correspond to the front intake bolt hole by the water passage.
That said you did the right thing by plugging them or oil would come out of them when you start the engine. They are open to the back pushrod passages as you can see in your first photo.
Just be sure they are short (~1/2") because if too long could hit the pushrod and bend it.
I believe the plug wire loom bolts to the passenger side one. The drivers side I do have a body ground bolted there.
Old 12-05-2013, 09:35 AM
unibody62's Avatar
unibody62
Thanks for your answer. Pretty much what I figured, but just wanted to verify with others. I used 3/4 in bolts, and they look like they clear by the time you add a washer and maybe another attachment in there.
Old 04-27-2014, 08:36 PM
Outlaw56's Avatar
Outlaw56
Outlaw56 is offline
Thats so funny, just found the same two holes on mine and was wondering what they were for.
HillBillyBuddha
02-11-2019 10:52 PM
blueturtle241
10-13-2006 12:33 PM
kalldp
1983 - 2012 Ranger & B-Series
08-27-2006 03:08 AM
77ford guy
05-01-2006 10:16 PM
jmayer
18
03-02-2004 02:31 PM
Quick Reply: purpose of bolt hole?
