1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
newbie F250 5.4L 3V HELP!!!
Old 11-25-2013, 06:57 PM
ikaro's Avatar
ikaro
ikaro is offline
P0340, P0344, P0345, and P0349, plus others...
The engine has 91,000 miles on it. I have read several posts. The engine will run good when cold. The engine does have a slight ticking after it warms up. When I come to a stop after the engine is operating temperature, the engine will start to miss and shudder and all 4 above codes come active plus codes P0012 P0022(must of the time), cylinder #8 “comes and goes” (It seems is works sometimes, at least that is what my mec said) and also NO Transmission Temp (don´t know if this has to do with anything or just another bad sensor unit). All 4 codes P0340, P0344, P0345, and P0349 are logged at the same time. I have replaced everything new (cam sensor, spark plugs, coils, vtc solenoid, new ECM) , the cam phasers where not replace, instead I pulled out ones from a perfectly running engine, installed them but had the same issue. At the end went and perform an engine overhaul. In cold starts, engine runs normal…. After a while once it starts getting warm again it start running rough and even stalling.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Also, if the engine is missing with the codes active and I rev the engine up it will come back to idle and run great. I have also unplugged each sensor with the engine running which has no effect on the way it runs.<o></o>
I’m out of options; waste lots of money (thought that the overhaul will be my solution) ; my mechanic is going nowhere now. <o></o>
Any and all thoughts will be greatly appreciated. Thanks.
<o></o>
Old 11-25-2013, 07:03 PM
khangmai's Avatar
khangmai
khangmai is offline
What year is yours? I think it has shorts or chafed wires somewhere. Just have to be patient and chase all the wires. Let us know what you find.
Old 11-26-2013, 03:49 PM
ikaro's Avatar
ikaro
ikaro is offline
is a 2008. If you have other advise.
let me know please
Old 11-27-2013, 01:07 PM
FoxNotch's Avatar
FoxNotch
FoxNotch is offline
I had a similar issue. It was the phaser:
https://www.ford-trucks.com/forums/1...iagnosing.html
cyco
09-24-2012 09:53 AM
btbell0615
09-20-2012 06:10 PM
Mean Gene55
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
22
10-08-2007 03:17 PM
simapg
Bronco II
12-21-2006 03:09 PM
Quick Reply: newbie F250 5.4L 3V HELP!!!
