Sultan/Monroe Area Shop
I presume you are referring to an auto transmission behind a gas motor. Not knowing what it is, makes it really hard to have an idea where to send you other than Smiley's for a flush/fluid change.
Make, Model, Year, Engine, Transmission. I only assume it is a Ford Truck you need worked on, probably a gas engine as they are more common, probably 4WD based on the area you live in.
I wouldn't tell you to take a Kia to Jim Greens or Dynamite Diesel or Kooey's.
Well IF you were down this way I would send you to this guy.
Casey's Trans-Plant - Complete Foreign and Domestic Transmission Repair and Rebuild in Tacoma, Seattle, Puyallup, and Olympia
Maybe he can tell you who up that way is a good pick.
Sean
Sean
Ok more info:-)
It is a 2001 F350 with a 7.3 Powerstroke 4X4 with an automatic. It has been the most expensive vehicle I have ever owned.
So I guess the better question I should have asked is "Can anybody recommend a good diesel shop in the Sultan/Monroe area that knows Fords?".
Thanks for your time and input!
Can't help any more than that.
But that shop that I recommended is very good IMHO.
Also there is the Power Shop in Enumclaw Home :: The Power Shop
But my all time favorite happens to be for Ford diesels.
Fugate Ford in Enumclaw. They have a very good rep for diesels.
Sean
Sean
raebear1
09-15-2015 05:02 PM
