2008 Navigator--Interior light problems
Old 10-25-2013, 11:36 AM
ASTROENG2011's Avatar
ASTROENG2011
ASTROENG2011 is offline
OK. I need some help. I have no interior lights coming on when you open the doors. Running boards extend when door opens but no interior lights. I checked fuse- still good. Lights work manually--come on when you push them. I checked the dimmer switch to see if it was in off position. Nope set mid range of control. So, where do I go from here. I seems there is another timer control or convenience control that tells the interior lights to come on and go off after a set time depending on door position(open or closed). I cannot find any such module. Anyone have any ideas where I should start to look?
Old 10-25-2013, 12:45 PM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
I don't know the answer for a Navigator, but if my Mercury Marauder had this problem I'd suspect the Lighting Control Module (LCM). I'd try to bark up that tree if you can find it.
AzSuperDuty
11-16-2014 05:39 PM
fuelman
02-03-2011 11:33 AM
danlee
Electrical Systems/Wiring
01-07-2010 06:23 PM
Suomi Powerstroke
12-02-2009 02:53 AM
scionti 94
06-26-2005 02:46 PM
Quick Reply: 2008 Navigator--Interior light problems
