Max overbore on a 292
Old 10-19-2013, 08:00 PM
69supercj's Avatar
69supercj
69supercj is offline
I've got a 292 that is already 50 over. Whats the max safe over bore? Also my crank is 20 on the rods and 10 on the mains, whats the most you can safely turn one of these?
Old 10-19-2013, 10:16 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
This guy sells .060 pistons, not sure your motor will clean up with only another .010.
Rod and mains out to .040.
Price Sheet
I remember my dad going on and on about a neighbor's Minneapolis Moline tractor motor have a rod journal turned .120, as he ran it pounding away for quite some time before the overhaul. So, sometimes you can go more than you think!!!
This is an old article, but it says you can go .125 on overbore.
http://www.oocities.org/yblockhead/HotRodding292.html
More of the same, different author it appears, or not...again, old article:
http://www.oocities.org/yblockhead/Y...fications.html
More recent article, 2009, again, talks .120 overbore:
http://www.rodandcustommagazine.com/tipstricks/74739/
Old 10-21-2013, 01:56 PM
312's Avatar
312
312 is offline
if its .050 over that's a stnd,312 piston bore.just buy a .030 or .040 312 piston enough to clean it up.
LedheadELH
01-30-2007 11:14 AM
Tony Montana
06-22-2006 05:22 PM
PSNut
02-01-2006 08:36 PM
46yblock
01-28-2006 09:06 PM
FordPerf300
17
06-22-2005 04:10 PM
Quick Reply: Max overbore on a 292
