Once it starts, slightly press on the gas pedal to raise the idle. Does it still stall then, or only at idle?
I had the same problem. If I gave it gas it would stay running. If I let it idle it would die. I had a bad IAC, idle air control valve. I replaced it and that fixed the problem.
It will run rough if I press on the gas pedal. I will check on everything everybody told me. Thanks on all comments. I will let you know in the next few days
