Factory wiper blades, frustrated.....
Old 10-03-2013, 04:36 PM
rolloman's Avatar
rolloman
rolloman is offline
2011 F150. My factory wipers are terrible about chatter. Bought a new set and they do it also. Anyone else have this and solve it with aftermarket?
Old 10-03-2013, 04:41 PM
svt2205's Avatar
svt2205
svt2205 is offline
You're just replacing the factory blades on a 2011? Wow, mine where junk within 4 months of buying the truck. But replacements have always corrected any issues. Granted some brands "seem" to work a little better or slightly longer. I guess it might be a thin layer of something on your windshield that's causing the chatter.
Sorry that I can't be more helpful.
Old 10-03-2013, 06:04 PM
MCDavis's Avatar
MCDavis
MCDavis is offline
I've had great luck with Bosch Icon wipers on my truck and the wife's sedan. A bit spendy but good. They are a mono beam and don't have pressure points like conventional blades. A good thorough scrub of the windshield or even clay baring it can drastically improve wiper performance.
Old 10-03-2013, 06:26 PM
Beach_Bob's Avatar
Beach_Bob
Beach_Bob is offline
I'm a Bosch guy myself. Time to swap to a new set for winter
Old 10-03-2013, 07:35 PM
tWyStyD's Avatar
tWyStyD
tWyStyD is offline
Talking
RainX works pretty good I find
Old 10-03-2013, 07:36 PM
PrinceValium's Avatar
PrinceValium
PrinceValium is offline
I agree with MCDavis...get that windshield cleaned. You need to get the windshield surface completely cleaned of any residual buildup or contaminants as well as cleaning the wiper blades off. You will not remove most contaminants with just windex, you need to use something that will actually LIFT off the contaminants. MCDavis is correct that claying a windshield will remove a lot of the contaminants from your windshield just like it does for paint. I have not tried the Bosch wipers as of yet but will do so when I have to replace mine.
Contrary to popular belief..RainX actually CAUSES blades to skip due to the ineffective way it tries to seal the windshield. Removal of RainX does not occur easily. I would suggest using denatured alcohol and a microfiber cloth. Be careful not to get that alcohol on your paint or it will effectively REMOVE your wax. Also no not ever use a scrub pad or anything like that on your windshield as it can cause damage. BMW actually says to use Bon Ami to clean your windshield if you have chatter from your wipers.
Bulletin Number: 61 02 94 (3990)
Noisy Wipers, Poor Cleaning: Group 61 Electrical
Woodcliff Lake, NJ
May 1994
Product Engineering
SUBJECT:
Windshield Wipers Are Noisy Or Do Not Clean Properly
MODELS:
All
Situation:
Windshield wiper blades may start to make noise, or fail to clean the windshield properly, even though the blades are not worn and are properly adjusted.
This can be caused by contaminants on the glass, such as oily road deposits or wax residues from car washes. These contaminants can cause the blades to chatter across the glass or fail to wipe cleanly.
Correction:
Common contaminants that are not removed by conventional glass cleaner can be cleaned with Bon Ami(R), a household cleaning product.
The cleaner should be applied on a wet cloth or sponge and the windshield must be thoroughly and evenly scrubbed. Wipe off residue with a clean,dry cloth before the product dries on the glass.
Hope this helps.
Old 10-03-2013, 08:31 PM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
  • Bon Ami
  • BOSCH
+1
-click- the pic'
Goth 150
< This space intentionally -blank- >
Old 10-03-2013, 11:30 PM
tvsjr's Avatar
tvsjr
tvsjr is offline
Trico NeoForms for me. Plus Trico View (aka Aquapel) rather than RainX.
Old 10-03-2013, 11:46 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
Yes, my wipers can chatter on my 2012. I just let the window get really wet before turning on the wipers. That cuts down on chatter.
Also, Rain-X washer fluid is the real deal. It cuts down the need to use wipers in the first place because the window is easy to see through even when raining. And the stuff really does remove bugs! Problem is it sucks at melting ice and leaves a foggy film on the window in cold weather that is hard to see through for 5 to 10 seconds after spraying. I switch over to old fashioned cold weather spec fluid in winter because it works better for that job. But in summer that Rain-X bug remover stuff goes back in!
Old 10-04-2013, 05:27 AM
rolloman's Avatar
rolloman
rolloman is offline
2011
bought the truck new in 2013. Figured they were old from just sitting. Looks like I'm gonna try Bon Ami since I do all the rain-x and rain-x fluid stuff and it didn't help. If Bon Ami don't work. Bosh blades next. The factory blades do it even in a good rain with a long time delay.
Old 10-04-2013, 11:20 AM
PrinceValium
Old 10-04-2013, 11:31 AM
blueovelboy's Avatar
blueovelboy
blueovelboy is offline
Originally Posted by PrinceValium
more force will not remove road grim its just a sales trick to get the weak minded
Old 10-04-2013, 11:33 AM
PrinceValium
I agree...however more downforce on the blades helps especially with wind.
Old 10-04-2013, 08:08 PM
gDMJoe's Avatar
gDMJoe
gDMJoe is offline
PrinceValium - I agree...however more downforce on the blades helps especially with wind.
The BOSCH blades have spoilers which address that ...
-click- the pic'
Goth 150
Old 10-04-2013, 10:27 PM
tvsjr's Avatar
tvsjr
tvsjr is offline
An added spoiler is good for +20HP, right? So two blades, 40HP. Win.
Quick Reply: Factory wiper blades, frustrated.....
