Windshield wiper kit wiring
Old 09-25-2013, 11:49 AM
old_dan's Avatar
old_dan
old_dan is offline
Has anyone installed the windshield wiper kit. I bought mine from Classic Haulers, but it appears to be the same one that Dennis Carpenter has.
The problem is that it came without a wiring diagram & there are 5 leads on the harness. I know that I need power and ground. I think the other leads are low speed, high speed, and park.
Does anyone have the wiring diagram for this kit?
Thanks,
Dan
Old 09-25-2013, 12:07 PM
r_reed's Avatar
r_reed
r_reed is offline
seems like classic haulers should be able to email you a diagram.
Old 09-25-2013, 08:06 PM
53OlderThanMe's Avatar
53OlderThanMe
53OlderThanMe is offline
Its likely the same kit or similar to what Mid 50s sells. Check on their website under instructions they have several versions as I recall. Had to do a little work on mine as the ground was wired into the connection plug in the wrong spot and it kept shorting when I switched to high.
Old 09-25-2013, 08:14 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
I looked on Mid Fifty, Classic Haulers and Dennis Carpenter. I see lots of instructions on Mid Fifty, but they're for Mid Fifties, not ours. No such instructions on Classic Haulers or DC.
The stock wiper motor has 3 leads. The case is grounded to the frame. The switch has 4 leads, all hot at some point. One is the voltage supply.
The way the original parks is by applying the same voltage to two contacts at the same time, equaling them out, and providing 0 volts difference in potential. It took me a while to figure out how that worked.
So, with 5 wires, I have to assume you have a ground, high speed, low speed and park. I have no idea what the other wire would be. Sorry.
Call Classic Haulers.
Old 09-26-2013, 06:56 PM
old_dan's Avatar
old_dan
old_dan is offline
I sent an email off to Classic Haulers. I was hoping that somebody here had the information at their fingertips.
Dan
rtcapo 61
04-09-2019 12:07 PM
1964FORDTUF
10-05-2016 08:47 AM
jstsumgi
09-14-2015 08:57 AM
northerncrewcab
02-19-2005 06:32 PM
Gary Kristiansen
08-19-1999 10:32 AM
Quick Reply: Windshield wiper kit wiring
