How do I fix this fuel leak?
So I got my van running again. While doing this I noticed I was dripping diesel when it was left running. Digging into it I found I was leaking fuel from here. It is circled in yellow:
Has anyone else had an issue with fuel leaking from here and is so how did you fix it?
Thanks
Thanks
Received 3,113 Likes
on
That is kind of what I was thinking. Just didn't know if I would have any issues with cold temperatures. We usually get a few sustained single digit (below zero at night) times during the winter. The van is parked outside, would I need to worry about it?
on
on
yeah just jb weld it.
if you want a fuel filter heater,consider installing a coolant filter and wrapping the two filters together to kill two birds with one stone,or buy a universal heater blanket.there's no need to tell ford it's ok to charge what they want for that old heater by supporting them with those ridiculous prices.example:
https://www.utahbiodieselsupply.com/...lterheater.php
IMO to keep it original, the filter head on the 7.3 is the high point of the system, and the return line leaving the filter head has a check valve, and small orifice in it, that when the engine's lift pump is operating a small amount of fuel is always returning to the tank, taking bubbles from tank slosh, with it down the return line's cooling the injectors along the way, the return line leaving the ip never seams to have anything coming out of it when I pull the hose off and look at it. the check ball is plastic and has a ultra lite spring that will get lost very easy if you remove the fitting and aren't ready to catch it. some persons have said that ford put out a tech bulletin that one could omit the return line from the filter head, I have not seen this bulletin, IMO to leave it hooked up. or the only way for air to get out of system is out the injector line's. The check valve should keep the filter from emptying out, when sitting. when the o ring in the heater rots it lets air in the filter head..
on
Oh, that explains why a fuel bulb/check-valve, put inline, solves all these problems... It *should* have had one from the factory, but by now it's gone/broken!
on
• Self-priming with a 10 ft. minimum lift
• Transient Protection
• Check valve
• 4 hour dry run
• Self-regulating
• 33 - 50 GPH
• 15 - 9 PSI
• VCA approved EC 95/54
• State-of-the-Art Electronic
• Sealed Electronics
• Reverse Polarity Protection
• Corrosion Resistant over 100 hours salt spray
• Durable Transparent fuel bowl
• Light Weight - 3LBs at 7 1/4”
• Low Power Requirements 1.4 amp on average
• Operating Temperature Range: -40F to 180F
Copedawg
09-20-2011 04:33 AM
