Newbie 85 f250 frame off resto (Image Heavy)
Old 09-17-2013, 09:01 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
What paint did you use on the drums? The other parts look like Eastwood's paint.
  #32
Old 09-17-2013, 09:11 PM
Piston Honda's Avatar
Piston Honda
Piston Honda is offline
Dupli color ford blue engine paint and cast coat aluminum. I'm painting the calipers blue too.
  #33
Old 09-17-2013, 10:48 PM
4x484150's Avatar
4x484150
4x484150 is offline
Your thread has inspired me to get a garage! Someday. Awesome work, when I do my restoration in however many moons from now, I would like to follow your example.
  #34
Old 09-18-2013, 07:04 AM
Piston Honda
Thanks! When we were looking at houses seven years ago we pulled in this driveway and I saw the garage I said "this is the one". My wife said" we haven't even went inside" " it doesn't even matter" I told her.
Well I didn't get any thing done on the truck yesterday I'm going to try and make some progress today.
Can anyone recommend a good paint gun? I need to pick one up pronto if I want to keep this project going seeing how the next step is to paint the chassis before I assemble the front end.
Btw thanks to everyone for the compliments!
  #35
Old 09-18-2013, 07:05 PM
Piston Honda
Alright guys, I'm really proud of this one. I tried out a welder I got a little while ago and made this piece up.
I also made a dust trap for the blast cabinet. Hopefully it will be a little easier to see while blasting the last of the pieces.
  #36
Old 09-18-2013, 07:17 PM
FordFETruck's Avatar
FordFETruck
FordFETruck is offline
The fabbed up piece looks great!
  #37
Old 09-18-2013, 07:21 PM
str8sixman's Avatar
str8sixman
str8sixman is offline
excellent job on the crossmember! i had the exact same peice rusted out on mine when i bought it, i ended up taking the crossmember out and turning it around as the other side was still good. not a proper fix but it will hold till i can get it fixed. let me know if you make more and want to sell one my way!
  #38
Old 09-18-2013, 07:25 PM
Piston Honda
Thanks. I'll probably have to do some more metal work to the rear cab crossmember. Either that or get another one some where. Are all years the same?
  #39
Old 09-18-2013, 07:31 PM
Piston Honda
It took a little while.If I charged by the hour it might be cheaper to buy a new truck.
  #40
Old 09-18-2013, 07:40 PM
str8sixman's Avatar
str8sixman
haha hey thats why we build em....its a great way to spend a little while
  #41
Old 09-18-2013, 08:19 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Good job! On my blast cabinet I use a $20 Craftsman shop vac with a drywall filter in it.
  #42
Old 09-25-2013, 08:39 PM
Piston Honda
We'll I had to take a few days off and do some other stuff but the blast cabinet works a lot better with the vac and dust trap set up, peices are all cleaned up. I did some fabrication on the rear cab crossmember, three areas on it were rotted.
I also sand blasted this crossmember again after fab but didn't take any pics, probably should have.
Cross members and shock towers are now painted and awaiting installation. I figure a few days and the paint should be hard enough to assemble.
Ended up ordering some better paint guns. They should be here in 3-4 days and the top coating can begin.
Next step transmission and transfer case!
  #43
Old 09-26-2013, 07:16 PM
86fordtruck's Avatar
86fordtruck
86fordtruck is offline
Good job, so far. Subscribed.
  #44
Old 09-27-2013, 09:46 PM
Piston Honda
I started in on the transmission and transfer case yesterday. Took the transfer case to the local transmission shop to have all the seals replaced and the housing cleaned up.
As you can see almost all the gaskets and seals are leaking.
Don't laugh at me for using the hoist to move the transfer case, I have a bad back right now.
I pulled the counter shaft rear bearing cap off and half the needle bearings fell out so I took the rest of them out and taped up the hole where the bearing race is and blasted it, cleaned it and put all the needle bearings back in with assembly lube.
Shifter cover cleaned up, don't know if I'll polish it up a bit.
Does anyone know how to take the shifter off of the cover? I still don't know.
  #45
Old 09-28-2013, 08:28 AM
truckertrav's Avatar
truckertrav
truckertrav is offline
If I recall, I believe you push down on the ring around the base of the shifter and turn to unlock from the drift pin...
Hopefully, someone will add to or correct me...(I haven't messed with trannys too much....Trav..
Quick Reply: Newbie 85 f250 frame off resto (Image Heavy)
