Newbie 85 f250 frame off resto (Image Heavy)
Old 09-16-2013, 09:09 AM
Piston Honda's Avatar
Piston Honda
Piston Honda is offline
A little history of the truck. The truck was a farm truck for the first 18 years of its life, so it's been worked. 88,000 original miles but looked like 388,000. My father inlaw bought it and let it sit like all of his other vehicles. He needed a place to park it, so it ended up in my yard. I used this truck when going to the dump and picking up material while renovating my house about six or seven years ago. I was driving it in a snow storm approaching a red light when the brake pedal went to the floor. So with no brakes there it sat for a year until he came and brought it to his new residence. It sat again until june of this year. I was looking to buy a truck when he suggested that i put some work into the 85. I knew this truck needed a ton of work and was reluctant to try and fix it. I had never attempted this much work to a vehicle. The price was right so I decided to bring her back to life!
I have begun assembling the chassis and have taken quite a few pics along the way. I'll post a few a day to get everyone up speed if anyone is interested in seeing a newbie trying his hand at a frame off.
Old 09-16-2013, 09:49 AM
str8sixman's Avatar
str8sixman
str8sixman is offline
ill gladly watch this one! ive been waiting for a good time/money situation to do something like that to mine
Old 09-16-2013, 09:58 AM
Piston Honda
Old 09-16-2013, 10:03 AM
JGreen236's Avatar
JGreen236
JGreen236 is offline
Looks good, what was your process on getting the bed bolts off?
Old 09-16-2013, 10:25 AM
Grubbworm's Avatar
Grubbworm
Grubbworm is offline
Subscribed.
Old 09-16-2013, 10:44 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Subscribed.
Old 09-16-2013, 10:46 AM
Piston Honda
Thanks! Two people, one under the bed one on top. I took a dull chisel and hit the high spots around the top of the carriage bolts and grabbed them with vise grips and heated nuts with mapp gas. They all came out no problems surprisingly. The bottom bed panels are toast so I wasn't worried about damaging them.
Old 09-16-2013, 02:38 PM
Pronk's Avatar
Pronk
Pronk is offline
Subsribed.
What are your plans for the frame?
Old 09-16-2013, 02:59 PM
nikmish's Avatar
nikmish
nikmish is offline
fun! give us more
Old 09-16-2013, 03:06 PM
Piston Honda
Originally Posted by Pronk
Subsribed.
I wire wheeled the whole frame and took a portable sand blaster to all the tight spots, cleaned and prepped using por 15 products then I put two coats of black por15. I did the same on the axles and som other misc pieces. I plan on going over the por with some tie coat primer and then two coats of topcoat.
Old 09-16-2013, 03:49 PM
Piston Honda
Originally Posted by nikmish
fun! give us more
I was only planning on releasing a few photos a day, but, alright here's some more
After you use the prepping spray it flash rusts but from what they say it helps the paint bond
...and some paint
Old 09-16-2013, 04:19 PM
4x484150's Avatar
4x484150
4x484150 is offline
In case you couldn't tell, we love pics here! The frame looks great.
Old 09-16-2013, 04:38 PM
Piston Honda
Thanks a lot! It came out alright, but it dried weird and seems flat in some areas and glossy in others. The paint is kind of hard to work with. That's why I have decided to topcoat after all leaf springs and ubolts are installed.
Old 09-16-2013, 04:49 PM
JGreen236's Avatar
JGreen236
I can't wait to do a frame off restoration on mine. How much money do you have in paint on the frame(estimate)? And is that a 351w HO you've got?
Old 09-16-2013, 05:06 PM
Piston Honda
Well, I haven't put the tie coat or topcoat on yet, so without that about $165. I still have 1 1/4 quarts left for underside of cab, bed and trans.
Not a HO just a reg 351w.
Another $50 for the marine clean and prep & ready
Quick Reply: Newbie 85 f250 frame off resto (Image Heavy)
