Oklahoma Chapter Join Chapter, Leader:
Need a A/C shop that will work on R-12 system.
Old 09-02-2013, 05:40 PM
Mustangking1's Avatar
Mustangking1
Mustangking1 is offline
Hello,
Title says it all.
I have a 1978 f250 that needs some a/c work.
I need to find a a/c shop that will work on my r-12 system
If you know of a shop in okc that does r-12 please let me know!
Old 09-08-2013, 02:12 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
SwOkcOffRoader is offline
If you get a conversion kit, oil and 134 freon, I have a vacuum pump and gauges to evacuate and fill it with 134. I have an R12 can tap, but I don't think it will hook up to my other tools.
Old 09-08-2013, 02:45 PM
Mustangking1
What all would I need to replace to convert to r134a?
Old 09-09-2013, 08:31 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Here's a link to one of the stickies in the 80-86 forum and you can see there two links regarding conversion to 134a: Link
Old 09-19-2013, 09:00 PM
SwOkcOffRoader
The conversion is simply a couple adapter pieces that go on the high and low fittings. You would need those, the proper compressor oil, and freon. Then hopefully the system doesn't leak and functions properly.
Old 09-19-2013, 09:11 PM
Mustangking1
I've heard before that you have to replace the drier/orfice tube?
Is the r134a as cold as r-12?
Where can I get the better r134a conversion kits?
Old 09-19-2013, 09:15 PM
Mustangking1
Also SwOkcOffRoader do you happen to have the r12 gauges to see whats wrong with my system currently?
Old 09-22-2013, 11:34 PM
SwOkcOffRoader
The gauges are the same, it's all about the fittings. I have gauges, but would need the fittings. Orifice tubes are inline filters, and cause most ac issues to begin with so yes I'd change it (if there is one) and the dryers are low dollar and can clog up as well. Most parts stores won't warranty compressors unless you buy those at the same time.
viper20b
Garage & Workshop
07-22-2019 05:45 AM
AeroStarOwner
Aerostar
06-22-2012 04:29 AM
octaneforce
27
04-03-2009 06:44 PM
Dave7.3
36
08-19-2007 12:31 PM
Rob88
03-28-2000 11:15 AM
Quick Reply: Need a A/C shop that will work on R-12 system.
