05 rear wheel bearings and seals.
Old 08-20-2013, 12:18 PM
dauntejoel's Avatar
dauntejoel
dauntejoel is offline
I noticed on the inside of my rear left tire there was oil on my rim. I took it to a garage and they said my seals are junk and my wheel bearings on both sides are bad. They want $1200 to do both sides. No way. I did the ball joints that wasnt bad. I wanna do it myself but im not sure what parts I need. Its a 05 f250. Any help would great.
Old 08-20-2013, 12:37 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
It isn't bad at all. I'd rather do that than ball joints.
https://www.ford-trucks.com/forums/7...ake-shoes.html
Josh
Old 08-20-2013, 12:44 PM
dauntejoel's Avatar
dauntejoel
The way the mechanic was explaining, he made it seems like a hard job to do. The link says rear hub seals are there inner and outer seals or just one seal on each side.
Old 08-20-2013, 12:45 PM
big inch's Avatar
big inch
big inch is offline
It's not a bad job to do. You will need a special socket to remove and install the axle nuts. Other than that, it is pretty straight forward.
Old 08-20-2013, 12:47 PM
big inch's Avatar
big inch
big inch is offline
There is just the inner seals. The outer is sealed by an o-ring on the axle shaft.
Old 08-20-2013, 12:51 PM
dauntejoel's Avatar
dauntejoel
Sweet. Thanks guys for the quick responses.
Old 08-20-2013, 08:53 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
I would be willing to bet that you are going to need parking brake backing plates when you get it apart. Dorman makes the backing plate. You will also need to order new parking brakes shoes and hardware since yours are going to be soaked in oil.
Old 08-20-2013, 11:22 PM
Lx460's Avatar
Lx460
Lx460 is offline
They're parking brakes...spray them off with brake cleaner and reinstall. You're not using them to slow the truck, they will be fine. Unless the are visually worn out, I would just leave them be.
Also make sure you drive your new seal straight and don't hammer the edges. Once it's in the hub it's over, so make sure the new bearings are in the hub first if you decide to replace them. Otherwise it's back to the store for another seal...doh!
It's also easier to adjust the parking brakes with the wheels off IMO before you drop it back down.
Old 08-21-2013, 11:15 AM
MisterCMK's Avatar
MisterCMK
The parking brake shoes are not expensive. The parking brake on these trucks isn't stellar to begin so it is silly to put the oil soaked shoes back in even if you did spray them off with brake cleaner.
pinbill
10-26-2018 09:15 AM
smlford
10-09-2013 11:47 AM
BDalton
01-07-2009 05:54 PM
95f150
05-07-2005 11:00 PM
t90hambone
06-20-2003 12:55 AM
Quick Reply: 05 rear wheel bearings and seals.
