477 Timing Gear Set
Old 08-19-2013, 02:24 PM
swglanville's Avatar
swglanville
swglanville is offline
477 Timing Gear Set
I am looking for a Timing gear set for a 76 F880 with a 475/477... So far I have found a listing for NAPA but they indicate none in stock and will have to wait for manufacturer... Piston Ring says they have the Crank Gear... Anyone knows of a good supplier that ships to Canada?
Still tearing apart the front on the engine to check on what parts are needed.. Still have the Harmonic Balancer and Timing Cover to pull.
It was running and died when it hit a bump and was towed Home... Crank turns, but Distributor and CAM are not...
Old 08-22-2013, 03:16 PM
swglanville
Hmm, I see that Napa listed the timing gear set also compatible with Ranchero 6.6 L 400 CID V8, Did the Ranchero use a 401ci SD engine? Any Chance of adapting the Timing chain set from that engine to work on the 477 (Adding 2 more bolt holes to the cam gear)... NAPA AUTO PARTS NAPA AUTO PARTS 75 Ranchero 400ci Timing sets 1975 FORD RANCHERO Timing Set
Old 08-22-2013, 06:40 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,597 Likes on 1,302 Posts
Not related at all.
Do you have this thing apart yet? I think the SD motors are gear drive cams, no chain.
Old 08-22-2013, 06:54 PM
swglanville
Yep, it is apart. Cam timing gear has a couple broken teeth, it sheared two bolts on the cam and the center pin on the cam. The crank gear is fairly worn and flattened...
Old 08-22-2013, 07:24 PM
85e150's Avatar
85e150
Was it a chain or gear drive?
So the cam is damaged also?
Have you pulled to rocker covers? If so, see anything interesting?
As you are finding, these are antiques and not the kind that are going to finance your retirement.
Depending on a lot of other things, this may be the time to repower or upgrade the truck. Thousands into a rebuild of this motor.....only you can answer that.
Old 08-23-2013, 03:57 AM
big job's Avatar
big job
big job is offline
A big A ouch. You say you can get a crank gear so I'd get it. Next the cam gear
couple broken teeth, thats no problem, going to need a new dowel pin. OK next
My concern would be trying to turn the camshaft by hand. In order for that kind of damage, something bad happened like swallowing a valve and a busted oil pump most likely would break the oil drive shaft. Or take off the valve covers
& look for bent pushrods or something. Think of people with "stuck or froze up
engines" which is always in these forums.. All it takes is just one stuck valve and you aint turning it over unless you break something! In your case I strongly beleive this is what happened. It takes tremendous force to wipe out teeth.
As far as the cam gear, for our shop, thats a common operation. We simply machine tooth implants & when done, you cant even see the repair. And yes its done old school with a shaper, mainly its expensive mill tooling to buy for a one off job in order to use a milling machine and that gets added to the customer so a shaper is indeed cheaper. Depending on damage, its only a $50 Job for implants "way cheaper than a dentist" !!
Old 08-23-2013, 01:52 PM
swglanville
Pulled valve covers nothing obvious, Guess I'll see when I get around to extracting bolts from the cam and try turning it and then check the oil pump with a hex shaft down the dist
Old 01-15-2014, 11:29 AM
johns294's Avatar
johns294
johns294 is offline
If you decide to replace the whole engine LMK. I may be parting out a 900 tow truck soon.
Old 10-23-2015, 03:52 PM
Beanscoot's Avatar
Beanscoot
Beanscoot is offline
"Next the cam gear couple broken teeth, thats no problem"
Big job, how can you replace and remachine gear teeth for $50?
Aren't these gears helical cut, and of involute tooth form...?
deputydog03
1997 - 2003 F150
11-05-2023 08:28 PM
Xwarrior86
10-08-2015 11:34 AM
rdweathers
01-03-2013 08:08 PM
KyleG
18
03-10-2009 07:32 AM
SPROCKET
11-10-2003 01:29 PM
Quick Reply: 477 Timing Gear Set
