Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Transmission problems
Old 08-19-2013, 12:06 AM
Kyleball's Avatar
Kyleball
Kyleball is offline
Hello all. My name is Kyle and I'm having some problems with my 1993 lightning. This is the first automatic truck I have owned so I'm a little lost when it comes to problems like these. So I bought a 1993 lightning that had been sitting for 10 years without running. After changing fuel injectors and other minor things I got the truck running. I took it for a test drive for the first time and noticed it shifted very hard in to every gear. It shifts like a manual trans when you dump the clutch. Yeah that hard! Anyone have a idea what it is. A little back info......... The od light is not flashing, I hook up the computer and got a high voltage / low voltage code and a code that said engine could not establish idle. The truck runs like crap when it starts then a check engine light comes on after a mile and the truck runs ok once the check engine light turns on. Any ideas? I'm more interested in the tranny problems but thought all info might help. Any ideas? It has a e40d trans in it.
Old 08-24-2013, 03:58 PM
AzPete's Avatar
AzPete
AzPete is offline
Did you flush the tranny and install new fluid? After so many years, the tranny may be gummed up and the valves take more pressure to move....allowing the shift to happen.
You may look.into the idle air control valve as gar as the idle. Again, lots of crud can build up over the years of not running.
Old 08-24-2013, 05:37 PM
Kyleball's Avatar
Kyleball
Kyleball is offline
Thanks that's the best reply I have gotten yet !
Old 08-25-2013, 12:35 AM
Kyleball's Avatar
Kyleball
Kyleball is offline
Just a update I changed the idle control valve and it fixed everything. Tranny works great now too. I guess the computer went in to safe mode. Thanks for the help. It's much appreciated !!!!!!!
Old 08-25-2013, 12:37 AM
Kyleball's Avatar
Kyleball
Kyleball is offline
Thanks AZPete saved me a lot of headaches !!!!
Old 08-25-2013, 02:43 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Reps given to Pete.
Stewart
goodwrench
03-14-2016 07:30 PM
Sflymotoc
07-28-2013 03:50 PM
kegomatix
01-05-2013 01:21 PM
68rs327
03-11-2010 08:40 PM
nardster
1978 - 1996 Big Bronco
11-09-2002 11:20 PM
Quick Reply: Transmission problems
