94 ranger 2.3 pleas help
Old 08-17-2013, 09:48 PM
stevesecoy's Avatar
stevesecoy
stevesecoy is offline
Okay Heres The Problem, Im Getting Fuel To The Rail, Getting Fire, But My Truck Wont Run.If I Spray Ether Into The Intake It Will Run As LOng As Im Spraying But Dies When I Quit.. I ReplCed The Fuel Pump, The EEc,Both Relays And ChEcked All Fuses! Please Any Suggestions
Old 08-24-2013, 08:21 PM
thunder74-79's Avatar
thunder74-79
thunder74-79 is offline
sounds like your injectors aren't firing.
Old 10-02-2013, 10:04 AM
Stinky1's Avatar
Stinky1
Stinky1 is offline
Have you checked your fuel pressure?
If you have pressure, then your injectors ain't working...like Thunder said.
"Something" tells the injectors to get with it, get working, NOW!!! It could be the computer, it could be a sensor, whatever it is...start there.
CoastyAV8R
1978 - 1996 Big Bronco
05-05-2018 08:58 PM
bluestang65
Escape & Escape Hybrid
02-29-2012 09:29 PM
GummyF250
01-17-2010 06:45 AM
brownie83
1999 to 2016 Super Duty
05-28-2009 01:11 PM
markinms
11-10-2003 10:44 PM
Quick Reply: 94 ranger 2.3 pleas help
