ABS light on, growling brake pedal
Old 08-10-2013, 11:15 AM
gears351's Avatar
gears351
gears351 is offline
Ok, 116k miles, new brakes (6k miles ago) and now the ABS light comes on, the pedal growls & vibrates and it doesn't want to stop like it used to. First real problem (other than a ghost tailgate opener) on my 07 Exp EL -
It sounds like the pads are gone so I pulled the wheels and the rotors are clean and smooth and the pad friction material looks brand new (inboard & out, front and rear). When braking the growl comes from the firewall by the pedal, the pedal jounces around and the truck takes a bit longer to stop - sometimes the ABS light is on sometimes it's not.
Searching the forum I think I'll try building a shield around the tone ring pickup on the steering column (there's a TSB about this) but I was wondering if the truck's diagnostics would tell me the ABS code or if I need a dealer to scan it for that.
Is there something common that goes out on these trucks that would cause ABS problems?
Thanks
foust123
05-07-2012 12:40 AM
budstadler
Aerostar
17
11-12-2007 02:18 AM
woodly1069
13
07-21-2007 07:07 PM
XylemXorro
03-26-2007 01:31 PM
awilliams197
01-26-2006 02:26 AM
Quick Reply: ABS light on, growling brake pedal
