How hard to swap a 42 59AB for a 49 8BA
Old 08-04-2013, 04:35 PM
Truckin23's Avatar
Truckin23
Truckin23 is offline
How hard to swap a 1942 59AB for a 1949 8BA into my 1942 ton & a 1/2 flatbed any unforeseen problems I'll run into .
Thanks Bob
Old 10-09-2013, 01:20 PM
52 4x4's Avatar
52 4x4
52 4x4 is offline
I've done this swap into the earlier car, and remember needing to get either a '48-'52 pickup or '49-'50 Mercury bellhousing and related starter plate. If you use the Mercury bellhousing, it won't have enough clearance for an 11" Long clutch. The 10" B&B Mercury clutch will work, but you would have to use the Merc. flywheel. I used the flywheel from the ealier engine on mine, but had to use a spacer and do some grinding on the back of the block to get enough clearance. I used the late Mercury water pumps with the narrow belts, but I think you can use the early pumps, fan, generator, etc. Your radiator hoses won't fit the heads, but I think you can now buy thermostat housings with the larger outlets so you can find standard flex hoses that will fit.
Old 10-27-2013, 09:42 AM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
52 4x4 has it about covered and I don't think you will have any problem with oil pan fit .
Inline66
06-04-2018 01:37 PM
awhtx
Large Truck
05-14-2010 08:42 AM
generaltso64
03-23-2010 06:24 PM
Henrys son
09-05-2009 02:09 PM
1986FordF150I300
06-15-2009 05:12 PM
Quick Reply: How hard to swap a 42 59AB for a 49 8BA
