MM Hub Problems Anyone Else Have Issues
Old 07-20-2013, 12:19 PM
FireFighter12105's Avatar
FireFighter12105
FireFighter12105 is offline
I have a bad vibration on my drivers side. Trying to get the drivers aide apart to take a look at the wheel bearing to see what it looks like.
I have a set of MM hubs on. I cant get the hub cover off to even look to see whats going on inside of it if anyrhing. I took all 6 screws out and its just as tight as it was with the screwa in. Ive tries both the locked, unlocked and everywhere in between position and it just wont come off.
The hub covera on both sides also have a bit of a wiggle to them, is this normal?
Old 07-20-2013, 12:51 PM
diehardstroker's Avatar
diehardstroker
diehardstroker is offline
When I did my wheel bearings (stock hubs) I used a brass hammer to lightly tap and I mean LIGHTLY tap it back and forth a few times then it just slid right out. You might try that.
Old 07-20-2013, 03:18 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Let us know what you find. I had MM hubs on my chev years back and they were great. I'd consider using them again.
Old 07-20-2013, 07:58 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
My dad has the MM hubs, hasn't had that problem. His problem is the Allen head screws keep backing out on there own. I can't see what would be holding them on unless a ring of rust is there. But they are stainless so that doesn't make sense either.
Old 07-21-2013, 03:30 AM
FireFighter12105
Well after some persuasion I finally got them off. Thought maybe the play in the shaft was a hub bearing, hubs are like new, so moved on to the wheel bearing, wheel bearing also like brand new.
What else qould leave all kinds of play on the shaft the wheel bearing and hub slip on to?
Old 07-21-2013, 07:48 AM
diehardstroker
theres a seal on that shaft that holds the shaft inside the yoke where the wheel bearing and hub go on to. bad seal maybe? I cant remember if movement is normal after the hub and wheel bearings are off, because that shaft is removed when doing ball joints and the only thing keeping it in there at that point is that seal.
when you spin your wheel bearing does it make a grinding/scraping noise?
Old 07-21-2013, 08:11 AM
1996pwrstrk's Avatar
1996pwrstrk
1996pwrstrk is offline
I just changed a unit bearing (wheel bearing ) on my F350 yesterday.It had been making a little noise for awhile and I had a strange wear pattern start on that tire then Friday on the way home it started growling so I stopped and grabbed one . I tore into to it yesterday it had no play in it that I could find and looked fine ( factory original part with 206,000 on it ) so I changed it anyway and yep it was bad even though it looked good. I would first look at your tires and rims, did you lose a wheel weight ? Move the tire around and see if the vibration moves with it.
When ever I install new hubs with Allen set screws like the MM's I put RTV on the screw and a dab in the screw recess ,makes every thing come apart easier and might help hold it together too.
Old 07-21-2013, 08:37 PM
FireFighter12105
Yeah it makes a dry metal on metal geinding noise and doesnt spin free at all. I have it all apart and what looks like was a bearing or a seal is all apart.
Thweaxel shaft was moving freely there was nothing holding it.How much play are they to have in them after taking off the hub and wheel bearing?
I could yake my tire and move it up and down and side to side but the wheel bearing & ***** joints are brand new
wrdabney
1999 to 2016 Super Duty
09-16-2013 08:04 PM
IPACA9
03-03-2006 08:44 AM
thaichefscott
09-24-2005 10:57 PM
mizzitch
03-12-2005 04:09 PM
Mike Earls
Offroad & 4x4
12-17-2002 09:50 PM
Quick Reply: MM Hub Problems Anyone Else Have Issues
