Master Cylinder - Booster Leak
Hello, Before I get into buying parts like crazy for no reason I would like to ask about this: Couple of days ago while driving downhill coming to a stop and waiting for traffic my brake pedal started to go down to the floor. replaced 2 rear wheel cylinder one was leaking bad 2 months ago.
Noticed as well that between the master cylinder and the power booster brake fluid leaking (picture below) the vacuum hose it's ok not broken or craked
My question: which one should be the problem causing the leak? master cylinder or power booster? and if this will be the cause for the pedal going to the floor.
Thanks !
Thanks !
77ford guy
04-10-2006 11:33 AM
77ford guy
04-09-2006 08:52 PM
