Australia Chapter Join Chapter , Leader: ChunderDownUnder
ABS Light on
Old 07-10-2013, 01:31 AM
Aussie BrianB's Avatar
Aussie BrianB
Aussie BrianB is offline
Question ABS Light on
Just removed the driver's side battery and charged it.
Replaced it and started the truck.
The ABS light now staying on.
Does something have to be reset after removing the
battery or do I have an ABS problem?
Old 07-10-2013, 05:58 AM
aussie_f350's Avatar
aussie_f350
aussie_f350 is offline
mine does too!! have you got the auto enginuity computer program? its awesome and reads codes for ABS. Mine is in left front wheel sensor!
Old 07-10-2013, 08:02 AM
Aussie BrianB
Sounds like I'm gonna have to bite the bullet and get the AE kit.
Old 07-10-2013, 04:57 PM
BigF350's Avatar
BigF350
BigF350 is offline
The wheel sensors on these go out eventually.
Usually it is the rear sensor (on top of the diff housing), and often a wipe clean will often sort it out again. Otherwise, check the wiring for the front two sensors (the wiring can flex/break). All the sensors are cheap and pretty easy to replace.
Old 07-25-2013, 06:05 PM
Aussie BrianB
Just had to charge both batteries, dead flat.
Have not driven the truck for over a week.
This is the second time since the alarm was
fitted and I never had the problem before.
Battery load tester shows batteries are OK
and I am getting over 14V when the engine
is idleing so the alternator is charging OK.
There is obviously something draining the
batteries while the truck is not being used.
I suspect it is related to the alarm and emailed
the installer last night, no reply yet.
Has anyone else had this problem with
Cyclops P775B alarm/immobiliser?
Not looking forward to the tedium of tracking
down the cause of the drain.
Old 07-26-2013, 05:00 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
I think the alarm is the drain. Try manually locking the truck - so DON'T activate the alarm (assuming you've got a secure place to park it) and see if the batteries hold the charge.
If I leave the alarm on on my truck it won't start after 2 weeks without charging one battery.
I'm starting to think that the alarm is more trouble than it's worth.
Old 07-26-2013, 09:56 AM
BigF350's Avatar
BigF350
BigF350 is offline
While I agree that it is most likely the alarm - pull the fuse for it, and see if you get the same problem - check the current across the alternator, if the regulator is on the way out, it may still be making 14V, but not much current
doubleford
10-29-2010 07:24 PM
cghstrojan08
1997 - 2003 F150
08-22-2007 10:35 PM
69ford99
1978 - 1996 Big Bronco
12-01-2006 06:01 AM
ROKNZRX
1999 to 2016 Super Duty
03-23-2005 07:25 PM
Jonesy44
1997 - 2003 F150
09-18-2004 12:06 AM
Quick Reply: ABS Light on
