1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
05 F250 6.0 rough running
Old 07-03-2013, 02:43 PM
Razorback Jeff's Avatar
Razorback Jeff
Razorback Jeff is offline
Exclamation 05 F250 6.0 rough running
At 154k I'm on a third set of injectors. Most recent issue was loss of oil pressure. Mechanic replaced IPR, IPC, Stand pipes and a fitting on the HPOP(the cause of oil pressure loss). While he had it apart, also did an EGR delete.
Ran great for 4 days and then started noticing a bit of rough idle intermittently.
The problem has progressed. He rode w/ me with scan tool attached and only errors are mass airflow and non correlating intake air temp. The problem comes and goes, but seems to be worse when warm. Any thoughts would be appreciated!
Old 07-03-2013, 07:21 PM
Dan Thorpe's Avatar
Dan Thorpe
Dan Thorpe is offline
Just a thought... VGT sticking? Probably wouldn't cause idling issues but one never knows!
Old 07-04-2013, 03:27 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
First off. Welcome to FTE.
The better place for you questions would be in the
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
You should get some good info. One good place to start is the tech folder.
Sean
fordguy281
10-30-2014 09:48 AM
Razorback Jeff
07-05-2013 05:50 PM
jonedoe
10-10-2011 11:26 AM
waterboy
07-17-2006 04:43 PM
Rocky Mountain Jeff
04-29-2005 04:52 PM
Quick Reply: 05 F250 6.0 rough running
