2008 Expedition factory installed remote starter giving 5 beeps and not working
Old 07-02-2013, 12:09 PM
Revrend O'Malley's Avatar
Revrend O'Malley
Revrend O'Malley is offline
I have a 2008 expedition with a factory installed remote starter. One little keyfob with one button. My truck was running the other day and I depressed remote fob until it beeped 1 time and kept the truck running so I could pull the keys and lock the truck. A few minutes passed and the truck shut itself down as it normally does. I re-depressed the fob to restart the vehicle and the truck beeped at me 5 times and hasn't worked and beeps 5 times I press fob ever since.
Any thoughts?
Thanks<!-- google_ad_section_end -->
Old 07-02-2013, 03:22 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Are you sure it's 5 beeps??
5 honks/beeps means the remote start is sensing the key is in the ignition. My guess would be the SecuriLock/PATS unit is at fault.
For future reference.
2 honks = Hood is open or brake is depressed
3 honks = One of the doors is open
4 honks = Tach is not programmed
5 honks = Key is in ignition
6 honks = System is in Service/Valet mode
Matt
Old 07-02-2013, 03:42 PM
Revrend O'Malley
Actually SIX beeps..
Hey Matt,
I just tried again - it is actually SIX beeps. Thoughts on how to remove from Valet mode?
Thank You!
Matt
Old 07-03-2013, 07:24 AM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
To return to normal mode:
Insert key and turn to ON or RUN ( foot OFF brake )
Press the remote start button on remote 3 TIMES.
Horn will honk 1 TIME indicating system is out of Valet Mode.
Remove key and test to make sure system functions normal.
Also, when using the "quick stop" feature make sure that your foot is not accidently on the brake as this can case the system to enter valet mode.
Matt
Old 06-26-2022, 02:51 AM
Sharrod27's Avatar
Sharrod27
Sharrod27 is offline
1st Gear
Matt
So if it really is five honks what is the problem and how to fix it
steveg_nh
11-26-2014 11:31 PM
LSchicago2
1999 to 2016 Super Duty
12-09-2009 08:12 PM
BillyBob69
1997 - 2003 F150
07-20-2005 02:33 PM
allanhilliard
15
06-14-2004 04:12 PM
lt284
10-15-2003 10:28 AM
Quick Reply: 2008 Expedition factory installed remote starter giving 5 beeps and not working
