Transmission type '93 F-150
Old 06-11-2003, 04:49 AM
Adrienc9's Avatar
Adrienc9
Adrienc9 is offline
How do I tell what type of automatic transmission I have on my 1993 F-150? I have the overdrive push button on the end of the gear shifter. I am having some weird things happen with it. Sometimes it shifts really hard going into second gear. Sometimes shifting in the higher gears, the engine RPMs go way up to about 4000 and then all of a sudden the tranny will catch. Other times it works great! Any ideas?
Old 06-11-2003, 09:59 AM
etucker's Avatar
etucker
etucker is offline
i think it may be a E40d tranny like in my 90 f250 I am having a little bit of the same problem. i am thinking it may be tranny fluid needing changed. i will let you know if that fixes my problem.
Old 06-11-2003, 12:18 PM
Adrienc9's Avatar
Adrienc9
Adrienc9 is offline
Please do let me know if that works. I just bought the truck a few months ago and am having some oil pressure problems with the engine right now so I am working on that first.
Old 06-11-2003, 01:05 PM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
You could have an E4OD or 4R70W(AODE-W). Both use all-electonic controls, so normal automatic transmission diangosis may not find your problem. Get a code scanner or have someone read diagnostic codes for you. Based on my problems with an E4OD, your fluid pressure is being regulated high in an attempt by the computer to compensate for another weak component in the transmission. Sometimes, just loose or dirty electrical connectons are the problem.
Jim
Old 06-11-2003, 10:03 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
check and make sure your valve body is tight when you change the fluid.
Old 06-12-2003, 11:46 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Could be the neutral safety switch. This switch also tells the ECM what gear you are in. I haqd to replace the one on my Windstar because it quit shifting all together. My freind had to replace one on his Sable because you could be driving down the highway and it would throw itself into low gear for no reason. Replaced the switch(located on the tranny behind the shifter linkage) and both are fine to this day. It was about $25 at Auto-Zone.
Jimmy
Old 06-12-2003, 11:50 AM
Adrienc9's Avatar
Adrienc9
Adrienc9 is offline
Actually there was a code showing the neutral start code but I didn't think it could be that. Maybe I will try that too.
Old 06-17-2003, 09:41 AM
etucker's Avatar
etucker
etucker is offline
well adrienc9,
this weekend I changed the transmission fluid. it just might be internal but all the gears that do work shifts in nice and smooth have not actually drove the vehicle on the road yet though just 10ft forward and backwards.
Old 06-17-2003, 06:51 PM
Adrienc9's Avatar
Adrienc9
Adrienc9 is offline
Thanks I am still working on my motor right now but the tranny is next.
Old 06-18-2003, 02:29 PM
t4kne's Avatar
t4kne
t4kne is offline
My 93 F150 was shifting very hard. Turned out to be a sticking govorner. I dropped in a pint of Lube-Tech and the problem was gone in 5 minutes of idling.
I had tried replacing the transmission filter and fluid and this had no effect at all. This Lube -Tech stuff worked great.
Old 06-20-2003, 07:17 AM
havack's Avatar
havack
havack is offline
The 93 has a Manual Lever Position Switch not the NSS. It lets the ECU know that it is in park or in Neutral for starting as well as each gear except O/D.
It is the E4OD and not the 4L70W. That one came in 97 I think, some in 96.
Old 06-20-2003, 09:58 PM
steve83's Avatar
steve83
steve83 is offline
The 4R70W was used as early as '95; possibly earlier. The TRANS code on the door sticker will tell for sure, though. The E4OD code is "E" and the 4R70W code is "U". You can also tell by the pan shape.
Old 06-29-2003, 12:19 PM
Pickup Man's Avatar
Pickup Man
Pickup Man is offline
Adrienc9 Replaced the mlps on my 94 5.0 4r70w because it would go to neutral between 3-4 after going down hill(no load) and start to pull again (load). It didn't do it all the time and you couldn't make it do it. Usually most often when hot and pulling load (boat). Takes 10min and cos t $70. Just do it! PM
Old 04-29-2020, 06:42 PM
Reese Blecha's Avatar
Reese Blecha
Reese Blecha is offline
​​​​​​Where did you put this at in the trans fluid or in the oil lol I'm new to this.
Old 04-30-2020, 07:27 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Welcome to FTE!
Given the age of this thread, it might be better for you to start a new thread with some detail of what you're looking to do and/or trouble you're looking to remedy.
alamartina
22
11-24-2013 12:12 PM
ravens fan
11-05-2012 10:29 PM
hulaman
09-07-2010 07:45 PM
dlsmithsr
12-02-2009 05:19 PM
omio
07-13-2004 08:33 AM
Quick Reply: Transmission type '93 F-150
