Australia Chapter Join Chapter , Leader: ChunderDownUnder
6.0 intercooler conversion
Old 06-29-2013, 06:26 AM
Aussie BrianB's Avatar
Aussie BrianB
Aussie BrianB is offline
Question 6.0 intercooler conversion
Is converting the 7.3 intercooler to the 6.0 one worth the effort?
Is there an aftermarket one that does a better job than the 6.0 one?
Old 06-29-2013, 09:25 PM
BigF350's Avatar
BigF350
BigF350 is offline
Depends, it is a better intercooler, and if you are running a tune/higher boost, it's definitely going to drop your temps. I haven't fitted one (my truck is also un-tuned).
There are others that are bigger (I.e. better), but all of them that I have seen are more expensive.
Old 06-30-2013, 05:33 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
Tossed this one up for a while now. Unless you are tuned to the hilt or are towing 20000pounds I wouldnt worry about it. Are you have EGT issues ?
Old 06-30-2013, 05:41 AM
Aussie BrianB
Brian,
Not having any problems at the moment but do intend doing the usual
mods and changing to a PHP tuner.
I'm not after extreeme performance just want respectable performance with 3tonne of caravan behind and a couple of hundred kg in the back of the truck.
I am more interested in reliability and longevity that drag race performance.
I have just found that the 4.2 turb landcruiser was struggling any time I
met an uprade and did not like hauling the van in 40 degree Adelaide summer heat.
I was just wondering if the change of intercooler would be a big help or just a few degrees less EGT for a lot of spanner swinging.
Old 06-30-2013, 02:19 PM
Nkelly's Avatar
Nkelly
Nkelly is offline
Farkall User
In Victoria with the cooler weather most of the time I wouldn't be too fussed,but if I move to mackay I will be putting a bigger intercooler in,most likely the banks intercooler 30% more air flow it also comes with bigger intercooler pipes,colder the air more air flow the better our diesels go..
My Nissan patrol I had with the 4.2 intercooled was a different truck on a cold morning compared too a warm afternoon...
Im a BIG believer in the cold air induction,thats why im busting too get my air filter changed from the cone K&N intake too something else sucking air out of the engine bay is a performance downer I reckon
Old 06-30-2013, 04:26 PM
ChunderDownUnder
Dont forget water injection. U get cooler Egt's. can be applied when needed and a HP gain as well. When you are pulling a 3 ton trailer up a grade its gunna get hot. Even the best IC wont give you what you need. IMO.
Old 07-01-2013, 02:15 PM
Nkelly's Avatar
Nkelly
Nkelly is offline
Farkall User
Hmmm looked at that,be a good thing why haven't you got it hmmm
Old 07-02-2013, 05:07 AM
ChunderDownUnder
Due to my own personal global financial crisis everything is on hold atm. But I do have plans. just dont tell MeMe.
Old 07-02-2013, 05:18 AM
Nkelly's Avatar
Nkelly
Nkelly is offline
Farkall User
I know what ya saying, Frustrating all these things we would luv to do and no fekkin money aaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhh
Old 07-02-2013, 05:50 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Just when I want to buy from the US the ar$e drops out of the Aussie $ Not really complaining, at least it'll give our farmers/manufacturers/tourism industry some relief.
But now I need to save for a couple more months before I can afford what I could have afforded 2 months ago.
Old 07-02-2013, 02:05 PM
ChunderDownUnder
Yes we have had a good run. But like all good things they must come to an end. I think it was around .85 when I started investing in Clay's retirement fund.
Old 07-03-2013, 04:37 AM
Nkelly's Avatar
Nkelly
Nkelly is offline
Farkall User
I had an excellent argument with lyn when it was over a dollar now im screwed
Robert6401
01-25-2011 11:51 AM
brownie83
13
09-09-2010 02:43 PM
Big_Man_Brad
08-11-2007 05:41 AM
schmity
18
12-26-2006 11:29 PM
kilroy99
07-29-2005 06:26 PM
Quick Reply: 6.0 intercooler conversion
