2001 F-150 Ignition cylinder and Steering Wheel lock dilemma!!
Hello, everyone. I'm a new member, and I am desperate for some feedback of ANY kind. I just bought a 2001 F-150 XLT and I've had it about 2 days. When I put the key in the ignition, the key won't turn forward to engage. There is no steering wheel lock issue, because it's not functioning. The key is a transponder key, and is the ONLY key (a total of 1) that the seller had. There is no key fob. I managed, after about 10 minutes of fighting, jiggling, and cursing to get the key to move forward, so the truck's ignition cylinder is currently in the engaged position. Lucky for me, the key slips right out. So far, my only option that I've come to understand is to pop the cylinder out (I can do this because the cylinder is in the engaged position and I have the key), go buy a new cylinder, have a locksmith re-pin the lock to my original key, and re-install. As far as I know, this should eliminate the PATS issue as it would be the same key for the ignition AND the door locks (no key fob). I'm hoping this is a cut-and-dry issue, but I'm not sure...anyone know if I will experience ANY problems with the PATS or the fact that the steering wheel lock seems to be either broken or damaged beyond the capacity to engage? I've heard horror stories of the steering wheel locking mechanism being in pieces inside the column making it hard to impossible to replace the cylinder. Any help or opinion would be appreciated! Thanks, everyone. I'm happy to be here!!!
MarineVeteran03
1999 to 2016 Super Duty
07-07-2018 10:47 AM
4EyedTurd
12-02-2010 06:16 PM
BRNN53
03-05-2005 09:46 PM
