EFI v8 swap
EFI v8 swap
Hi i am trying to find out as much as possible fitting a ford efi v8 engine out of a econoline E150 1989 with od in my truck.I am not sure were to ask so i thought i would try here but welcome you to give me advice.I am want to find out is the a stand alone ecu that could be brought for this engine if so who who sell one.Is this engine the same as the 302 mustang will the mustang engine parts fit the engine i have as all i have been doing is google ford econoline parts.Also can i make my gearbox floor change i think its a C6 with od.Thank you
on
this is a very popular swap not only for these trucks but a whole range of classic Fords. lots of articles on the internet on how to do it. lots of aftermarket wiring kits available to do this also. i would check sites like Jegs, Summit, Painless Wiring and Ford Racing to see what they offer. you can use the stock computer and wiring harness from the van but you would need a wiring diagram to figure out what wires to use and not to use. my opinion you are better off using an aftermarket ecu and wiring harness as they usually come with simplified wiring and instructions of how to hook it up and the ecu are usually programmable. you will also need to upgrade the fuel system to a hi pressure unit with return line.
the mustang engine is the same but different. uses a better intake and injector setup along with a better cam and factory headers. but there is such a huge aftermarket for these EFI 302/5.0 engines that i wouldn't be to worried about where i got the engine out of. you can make some decent power with the right selection of parts.
good luck
Mike
good luck
Mike
I am in the middle of collecting a Mustang EFI setup for my 68' Bronco. You can use Explorer parts as well and Ron Francis makes a killer harness that you can have them switch the sensor plugs to explorer or mustang, whichever you plan to use. Mustang setup and ECU is the most popular route as the explorer harness is OBDII.
Here are some good links on 302 EFI
RJM Injection Tech — RJM 5.0L EFI Harness Compatibility List
http://oldfuelinjection.com/
and this one that is more Bronco specific but still very relevant.
http://oldfuelinjection.com/Inject_your_horse1.pdf
http://oldfuelinjection.com/Inject_your_horse2.pdf
http://oldfuelinjection.com/Inject_your_horse3.pdf
FlaresideTyson
13
01-05-2019 09:13 AM
