Transit Connect 2010+ Ford Transit Connect
Real world use and mpg from a TC 2.0L.
Old 06-23-2013, 06:58 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
WOW..... I first got interested in Transit Connects back in 2008, WHAT THE...........
I started a new job this past Tuesday and the round trip is around 50 miles. My poor 4.2L 167,000 mile ladened
F150 is starting to provide lower that desired MPGs. I use around 4 gallons on the round trip and at 4.30 a
gallon, I am considering a used TC (around $20,000 for a 2010 model).
Can the TC with a 2.0 handle around 500 pounds of tools?
Portable tablesaw, chopsaw, extension cords, drills, etc. - pretty much most of my carpentry tools and
equipment.
What kind of real world MPGs can I expect from a 2.0 TC? I spend around 400.00 a month of fuel, but
economically it would not make sense for a TC loan payment and a higher than desired fuel cost from the TC.
The other option is a new 4.2 in the F150.
Thoughts - good, bad, indifferent?
Who has a loaded daily driver Transit Connect? Help!
Old 06-24-2013, 06:25 AM
pbeering's Avatar
pbeering
pbeering is offline
TC payload is a tick below 1700#. Mine scales at 5030# fully loaded. I have seen MPG of low to mid twenties in town.
Old 09-02-2013, 08:12 AM
ncranchero's Avatar
ncranchero
ncranchero is offline
My 2010 sees max lbs regularly, gets 25 mpg running highway speeds, has 167k miles and had no trouble at all out of it.
Old 10-07-2013, 06:46 PM
Little General's Avatar
Little General
Little General is offline
My 2011 TC fully loaded with plumbing repair parts doing mixed driving thru Charlotte, N.C. traffic is getting 23mpg with no problems . Just normal oil changes with 25k miles.
Old 11-09-2013, 03:15 PM
FordBlueHeart's Avatar
FordBlueHeart
FordBlueHeart is offline
My 2010 TC has a ladder rack on it. I took the ladder off from it because it cost 1-2 mpg. Most of my driving is highway and freeway. Here in Michigan that means 60mph on the highway and 75mph on the freeway. Where I drive can be hilly, never flat for more than a few miles. With that said, the best I ever got for a tank was 23mpg. The worst was just under 20mpg. 75,000 miles on it when I left that job.
Old 11-09-2013, 04:34 PM
ncranchero's Avatar
ncranchero
Mine is at 176K now and still motoring right along, 24-25 mpg.
Old 12-06-2013, 08:25 PM
acf6's Avatar
acf6
acf6 is offline
Our 2010 has about 16k miles on it, and i believe gets around 22 mpg. Probably be better if your foot wasnt to the floor the entire time, but thats the only way you can get anywhere in it. Barely makes it up some small small CT highway hills here at 70, nevermind with something in the back
We mostly just use it as a transportation for tools/materials to jobs and for errands. the F450s do the work
Old 01-16-2014, 08:11 AM
newstylecustoms's Avatar
newstylecustoms
newstylecustoms is offline
My company truck is a 2013 Connect and only has 6k on it. Every tank so far regardless of how it is driven or where it is driven (usually a mix of city and highway) it gets 24-25 MPG. Not much weight though just small tools and supplies.
Old 01-16-2014, 06:33 PM
ncranchero's Avatar
ncranchero
Mine now is at 185K and still runs and drives solid. MPG's are still 23/24 with my foot on the floor!
Old 02-21-2014, 07:39 PM
Little General
Mine is now at 45,000 miles and has no problems other than the crappy tires it came with. I put on a set of top of the line Goodyears and its good for another 45k. I was worried about the truck holding up, so I bought an extended warranty. Also, I bought new for the same reason. Having owned one for a while, I would not hesitate to buy a used one from the cable company / alarm company/ etc. at an auction or lease turn ins.
Old 05-19-2014, 10:22 PM
Van Diemen's Avatar
Van Diemen
Van Diemen is offline
2012 here with 56k miles. Loaded with racks and tools. Not a single issue so far. I've moved close to 2000# (20 bags of Portland cement) on a few occasions. My Mileage mixed city/hwy is 22-25. Got 50k from the original tires (Conti's) and didn't think they were that bad so replaced with same.
This van replaced an '06 F350 Diesel and the money saved on fuel, driving 35k miles a year, almost pays for itself.
Old 05-20-2014, 12:27 AM
ncranchero's Avatar
ncranchero
I'm at 202K now, highway miles mostly. MPG's haven't fallen and still problem free.
My new TC will be here in about 3 months!!
DDT11
2017+ Super Duty
44
01-20-2017 10:04 AM
17 Oaks
1999 to 2016 Super Duty
10-05-2016 07:56 AM
MidMichigan
6.7L Power Stroke Diesel
13
05-15-2012 09:57 AM
captaineddie
2009 - 2014 F150
33
03-26-2012 05:45 PM
djjoshuad
16
09-22-2010 02:20 PM
Quick Reply: Real world use and mpg from a TC 2.0L.
