Just an update.
Old 06-21-2013, 07:58 AM
rottenstock's Avatar
rottenstock
rottenstock is offline
Just an update.
Hey Folks,
So I missed the get-to-gether apparantly. Guess i'm not as active in these forums as I should be.
Anyways, I just wanted to give you folks an update on my truck so far. I spent father day weekend doing the power steering conversion so I could get rid of that ram assist steering and over all it went pretty well. Have a couple issues that i'm working through, but overall, not bad.
Here's my album for the conversion: rottenstock's albums - Imgur
I'd really like to clean up my truck some more, but I think it's too far gone for what I have invested into it.
Old 06-21-2013, 08:04 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Morning! Nice job on the conversion. I've got to do the same on my 73 highboy/53 panel project. You missed a great GTG! Good people and a great day was had by all!
Old 06-21-2013, 07:21 PM
bertha66's Avatar
bertha66
bertha66 is offline
I will have to go though those pictures. What kind of box did you use? I have a 76 F250 4x4 that I would like to change the steering on.
Old 06-21-2013, 11:55 PM
rottenstock
I used a steering box from a 79 F-350 4x4. They are apparantly really sought after. I ended picking up box and pitman arm for $100 and got the drag link for $20. The peice of steel I got was like $22.
If you're gonna do it, I'd say cut the core support so you can scoot it back from the core support a little.
Old 06-22-2013, 08:31 AM
bertha66's Avatar
bertha66
bertha66 is offline
Thanks, I will have to look for one of those.
Old 06-22-2013, 09:35 AM
fabmandelux
Make that 2...........................lol
Old 06-23-2013, 04:09 AM
rottenstock
the 2wd boxes work as well. Make sure when/if you do it you measure correctly.
I didnt cut into my cross member so my steering is a bit off. I've got more left steering than right.
I'm going to look into an adjustable drag link configuration.
Old 06-23-2013, 08:09 AM
bertha66's Avatar
bertha66
bertha66 is offline
I did a adjustable drag link on the power steering conversion on my 66 F100 4x4
Old 06-23-2013, 06:06 PM
rottenstock
did you end up just using two tierod ends and a sleeve or was there something special?
Old 06-23-2013, 10:18 PM
bertha66's Avatar
bertha66
bertha66 is offline
I cut my old one and one from a Chevy that had a whole in it that fit on the ball joint that was on the Toyota steering box and put a turn buckle with right and left treads, so it can expand and contract as needed.
Old 06-26-2013, 12:44 AM
rottenstock
got a picture?
Old 06-26-2013, 09:49 AM
bertha66's Avatar
bertha66
bertha66 is offline
Originally Posted by rottenstock
got a picture?
I will have to see if I can get one.
Old 06-26-2013, 09:40 PM
bertha66's Avatar
bertha66
bertha66 is offline
The shot of the left end with the zert fitting is the Ford end and from the turn buckle to the right I cut out of a Chevy truck drag link.
Old 06-27-2013, 01:43 AM
rottenstock
Ah, so you did the cross over steering sorta?
Old 06-27-2013, 03:48 AM
bl1ndman's Avatar
bl1ndman
bl1ndman is offline
Hello everyone,
Last fall I picked up a 77 highboy and was just wondering how much of a difference it make replacing the power steering and how much work is involved? I entend to mostly use my truck on logging roads so I am wondering if it would be worth it.
Quick Reply: Just an update.
