feedback carb using arduino control
Old 06-20-2013, 12:02 AM
muscletruck7379's Avatar
muscletruck7379
muscletruck7379 is offline
have been tossing around the idea of actually willingly installing a feedback carb on something like my highboy or falcon but rather than using all of the factory stuff strip it down to some essentials- tps sensor, map sensor, and o2 sensor, then write up a program to use an arduino controller to run it. mostly as an alternative to running alot more wires to even just do a TBI, plus I wouldn't have to set up a high pressure fuel system. hopefully taking advantage of a better understanding of what wasn't done right with these systems.
since most of the carbs were ran via pulse-width modulation, it shouldn't be too horrible to create a basic table that could slightly adjust the A/F ratio without going wild. any thoughts?
Old 12-04-2013, 05:01 AM
1985tullyhowell's Avatar
1985tullyhowell
1985tullyhowell is offline
brilliant idea
variable air /fuel carb
Old 12-04-2013, 08:20 PM
muscletruck7379
im glad somebody thinks so...
Old 12-05-2013, 12:05 AM
1985tullyhowell
haha
if I had more finances and the know how ,when I first got my truck (and previous owner did butcher things ) I probably would have done that or re map a modern ecm
or renix it (I know it has a bad rep. but it is reliable and it does use simple ways of running) grounding and and owners who didn't know what to do
pipe364
08-01-2010 02:01 PM
vboxingguy
03-12-2007 10:52 AM
DT 466Man
07-03-2005 07:24 PM
fordmanSLO
1983 - 2012 Ranger & B-Series
04-30-2002 09:14 AM
berso
Bronco II
06-11-2001 04:11 AM
Quick Reply: feedback carb using arduino control
