Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
53' F600 front engine mount
Old 06-12-2013, 09:46 PM
Lott's 53' F600's Avatar
Lott's 53' F600
Lott's 53' F600 is offline
I discovered the large truck forums and figured my question would be best for this forum. I have a flatty 239 out of an F250 that I would like to put in my F600 big job. Did the big trucks have a single front engine mount that bolted onto the front of the flatty? I think i found the plate on ebay i will try to post the link.
Thanks
http://www.ebay.com/itm/1949-1950S-FORD-FLATHEAD-RAT-ROD-Front-Motor-Mount-for-Restore-/271202857835?pt=Vintage_Car_Truck_Parts_Accessories&hash=item3f24f3336b&vxp=mtr
Old 06-20-2013, 04:18 PM
Tatum81's Avatar
Tatum81
Tatum81 is offline
I have a 53 f600' mine has the 337 flathead. I will take pics of the front motor mount this weekend for you. I don't think that saddle in your pic will mount in your big job, too narrow. But I will confirm with pics and some measurements for you to reference.
Old 06-28-2013, 06:56 PM
Lott's 53' F600
Thanks for your help Tatum81. I looked at my truck the other day and I'm a bit confused I see there r two front motor mounts holding the current engine in (a 223 I think). From what the data tag says this truck originally had the flathead 254 in it if this helps. I'm also wondering which oil pan I need? I heard that there was a special pan to clear the front axle in the big trucks?
Old 07-07-2013, 11:29 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I have a 1953 F600 mine has the 337 Flathead.
Not 'as original' it didn't, the 337 flatty has been swapped in, originally came with either a 215 OHV I-6, 254 I-6 flatty or 239 V8 flatty. 223 OHV I-6 introduced in 1954.
337 flatty: 1948/51 F7/F8 & 1949/51 Lincoln/Cosmopolitan. 1952 F7/F9, 1953/55 F700/950 would have come with 279 or 317 OHV Lincoln derived Y blocks.
Left pic at left: 1950/53 254 I-6 flattie // Left pic at right: 1952 F1/F6 & 1953 F100/600 215 OHV I-6 front engine support.
Engine code 4th digit of VIN / 1953 F100/600: D = 215 OHV I-6 / M = 254 flatty / R = 239 flatty. No engine code for 337, cuz it wasn't available after 1951.
Old 07-09-2013, 09:04 PM
Lott's 53' F600
Thanks for the help Number Dummy. I purchased a parts manual on CD and I'm realizing how many parts differ from the 254 to the 239 in 53'. Luckily it turns out that my uncle has a running 53' f600 with the 239 flatty and hes just down the road. Any suggestions on where I can find some of these hard to find big truck parts? I will try to call JobLot Auto soon to see what they have. I need an oil pan, clutch housing, front mount and the frame cross member to go with it, and many more.
Old 07-09-2013, 09:20 PM
NumberDummy
Type the part numbers into rearcounter.com & PartsVoice.com .. to see what might be available NOS
usmcdad
04-29-2016 12:21 PM
Yellowstonequake
01-29-2012 06:43 PM
kinabro
09-22-2011 07:59 AM
arrowheadfred
07-12-2011 12:22 AM
jmadsen
15
04-05-2008 05:19 PM
Quick Reply: 53' F600 front engine mount
