Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
2005 - 2008 Ford F250 Truck Super Duty Ignition Coil (Set of 8) for V8 5.4L
Old 06-12-2013, 02:39 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
CHECK HERE FOR GREAT PRICES 2005 - 2008 Ford F250 Truck Super Duty Ignition Coil (Set of 8) for V8 5.4L
FREE SHIPPING IN THE LOWER 48 STATES!!!
The ignition coil is a crucial part of your ignition system. It's function is to convert the 12 volt power of your vehicle's electrical system in to 35,000 or more volts. This produces a high intensity spark at the spark plug which then ignites the fuel in the cylinder. Coils in general will wear out over time. This will cause a misfire condition. In engines like this with one coil per cylinder you can diagnose a coil by putting a timing light on each one to make sure it is lighting the light consistently.
This coil over plug Ignition Coil SET features the following specifications:
Comes as a SET of 8
Brand New
Replaces dealer part numbers: 3L3E-12A366-CA, 3L3E12A366CA, 3L3U-12A366-BB, 3L3U12A366BB, 3L3Z-12029-BA, 3L3Z12029BA, DG 511, DG511
Built to strict quality control standard
Direct replacements
100% factory tested
This coil is a distributorless application. Sold as a SET of 8.
These are electrical parts and are all tested before they leave our manufacturer. This electrical item is not returnable; it is only eligible for exchange.
1 Year Warranty
This item is backed by a 1 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty.
1Aauto
04-04-2014 02:30 PM
Quick Reply: 2005 - 2008 Ford F250 Truck Super Duty Ignition Coil (Set of 8) for V8 5.4L
