Bio Diesel Newbie
Bio Diesel Newbie
Hey Folks,
While I'm not new to the world for Ford truck diesels, I am new to the idea and potential following thru of making bio-diesel. If I do go through with this "project" I want to go ***** to the wall. I have even gone as far as debating buying a turbo-diesel Jetta (an older on) to replace my current gasoline vehicle, assuming I can do this. Between the already incredible high mileage of the jetta and the "free" biodiesel I should theoretically be at a "0" cost for my fuel. This would also allow me to run my Powerstroker much more often without fearing the fuel bill at the pump!
I've been doing initial research on how the process works. I get you add lye, methanol and shake, let it sit then "sift". I know there is also a lot more involved like washing, etc.
SO that being said I"m looking for some web-site research. Are there good sites to get started on? I didn't see any stickies in this forum (ahem...perhaps someone could make a sticky??? LOL)
Thanks so Much
and Happy Rattling!
Al C
Thanks so Much
and Happy Rattling!
Al C
Here's a link to what I believe, is the best place to get started:
http://www.make-biodiesel.org/
It has the latest information on everything for the homebrewer.
Good luck, and any questions along the way are answered here in this forum quickly and thoroughly.
Since you are just starting, you could look into WVO instead of BioD. WVO is just filtered and dewatered veggie oil, and BioD is chemically treated veggie oil. The goal of running any veggie oil in a Diesel engine is to lower the viscosity of the oil to something close to the viscosity of Diesel. So, you can either heat it from the tank to the IP (WVO) or chemically treat the veggie oil (BioD). The upfront cost is more to install a two-tank WVO system, but the cost of processing WVO is nearly nothing since it is just filtering and settling. The upfront cost of BioD is less (replacing seals and hoses), but it costs more to make your own BioD in the long run.
Up to you. There are other pros and cons.
I gotta agree with Gene...
Do you really want a bunch of caustic acid, and methanol laying around just waiting for a spill?
Wvo (imo) is just safer to deal with... and comparatively less expensive to process...
Granted... converting the truck is a bit more involved... addition of 2nd fuel pump, filter, and heating system...
carguy3j
15
02-13-2018 10:14 AM
okrp
Bio-diesel, Propane & Alternative Diesel Engine Fuels
02-23-2013 10:37 AM
Finnzo
12-04-2007 02:22 AM
mschultz
101
05-10-2006 09:04 PM
