ECM trashed...need helplooking for a replacement
Old 06-02-2013, 10:26 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
Unhappy ECM trashed...need helplooking for a replacement
After a year and a half struggle of either running ok or running poorly enough to not dare pull into traffic with my '92, 300, manual trans, I pulled the ECM out of it. Low and behold all of my frustration was evident when I saw the caps had leaked fluid all over the board. One cap destroyed "2" traces on the board and warped it, and the other burned the pole which it was soldered to. I tried to jumper the 2 traces and installed the new caps, but now the fuel pump runs continuously and doesn't communicate with the code reader.
I looked up the ECM code T2D1 and I have found several for $177. I found another unit for a '93, all same, but different year. Mine has the prefix F2TF whereas the '93 has F3TF. Suffix for '92 is ASB and the '93 is XB. Both for 5spd, 4.9L.
Can I save some dough and go with the '93? Thanks again!
Old 06-02-2013, 10:07 PM
timbersteel
Bumping this after 79 views...
Old 06-02-2013, 10:35 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
I can't answer your question, but you might PM number dummy https://www.ford-trucks.com/forums/p...newpm&u=368968, he should be able to give you an answer...
BTW free bump..
Old 06-02-2013, 10:44 PM
timbersteel
Thanks for the reply White! Also, I never listed the price of the '93 ECM. It's $100 or less depending on best offer or local jys and fuel.
Old 06-03-2013, 05:52 AM
UncleCracker302's Avatar
UncleCracker302
UncleCracker302 is offline
Try autocomputerexchange.net <------ had good pricing, customer service, prepaid postage for return, etc. since you have your part numbers, should be easy to get them the info.
Nick Kropat
08-06-2017 08:04 PM
DPDISXR4Ti
03-09-2013 07:25 PM
PathAss
03-10-2012 10:31 PM
AG4.0
Computer Chips & Tuners
07-31-2004 09:14 PM
Quick Reply: ECM trashed...need helplooking for a replacement
