Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
hydraulic pumps
Old 05-15-2013, 06:23 PM
Wes(MI)'s Avatar
Wes(MI)
Wes(MI) is offline
hydraulic pumps
What size/style of crank driven hydraulic pumps did they use on these trucks? I'm in the process of converting a PTO winch to hydraulic operation. It's going on a '79 F700 w/370 bb. Thanks.
Old 05-15-2013, 11:32 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Wouldn't you want to run the winch pump off the PTO?
If you have a crank-driven pump, it would be turning all the time.
Old 05-16-2013, 10:39 AM
Wes(MI)'s Avatar
Wes(MI)
Wes(MI) is offline
Not necessarily. If I decide to add other hydraulic options to it layer, a PTO pump could be a hindrance. Take a snow plow for example. You don't always drive at 2k rpm or less.
Old 05-17-2013, 11:27 PM
dmanlyr's Avatar
dmanlyr
dmanlyr is offline
There is pretty much no standard here. It is whatever the particular aftermarket company came up with.
Two choices of pump mounting, directly on the engine or in front of the engine driven by a short driveshaft.
Ford might have, or had at one time a accessory pulley* kit which could be adapted to a engine mounted style pump, the front mounted w/shaft would be up to the final modifier. Yes, there are systems that modify the radiator and run the shaft thru the core to the pump.
* one thought would be if you had a air compressor or not. If not, then you could probably get the mount and pulley kit for that and adapt it over for a mount and v belt drive for a engine mounted pump. Use a 12v clutch, and you can engage and disengage the hydraulics as needed.
David
Old 05-18-2013, 03:31 AM
80broncoman's Avatar
80broncoman
80broncoman is offline
I have quite a few mounted up on the engine driven buy belt and a electric clutch.
This was mainly on auto trans tow truck in the 90s'
Old 05-18-2013, 07:04 AM
HOTWRENCH's Avatar
HOTWRENCH
HOTWRENCH is offline
HYDRAULIC PUMPS
There are many choices on setting up a remote hydraulic system, PTO off of the transmission, belt driven from the engine , crank driven from the engine. All these are easy to set up , but some are quite costly. The easiest is probably the belt driven clutch pump, this gives you hyd power at the flip of a switch, this is what we use for wreckers, dumps , and snow plow setups. PTO trans driven pumps are more expensive and most can't be used while vehicle is in motion, we use these on larger dumps and wreckers ect. Crank driven pumps are mainly used on state snow plow trucks , utility line trucks with cranes or man lifts , also very expensive. There is a device that can be wired in to the hyd clutch pump curcut that won't let you engage the pump above a set rpm.
I Hope This Helps --- Hotwrench
Old 05-18-2013, 08:30 AM
dmanlyr's Avatar
dmanlyr
dmanlyr is offline
FYI - There are PTO drives that can be used while driving. The Allison automatic in my dump truck supports this.
David
Old 05-18-2013, 09:00 AM
HOTWRENCH's Avatar
HOTWRENCH
PTO'S
I said most not all-- I am very familiar with all types of PTO'S and hydralic pump drives as I have serviced and installed them for many years.
Have A Good Day ------ Hotwrench
Old 05-18-2013, 11:04 AM
dmanlyr's Avatar
dmanlyr
dmanlyr is offline
Opps, sorry I missed the most. I bad
David
Old 05-19-2013, 05:40 PM
Wes(MI)'s Avatar
Wes(MI)
Wes(MI) is offline
I've given thought to the belt style pump, but there's always the *potential* for belt slippage under heavy use. That's why I was thinking crank mount. Anyone have any pump part numbers or flow rates for one?
Old 05-20-2013, 07:21 AM
HOTWRENCH's Avatar
HOTWRENCH
Talking HYDRAULIC PUMPS
Check out www.surpluscenter.com they have about anything you could want in the hydraulic line and the prices are'nt bad. As far as belt slippage on clutch pumps it's no worse than any other belt drive unit. Most clutch pumps use two belts and are mainly trouble free. Finding the adapter for the crank on a crank driven pump may be a problem. Some have to be custom built .
Have A Great Day ------ Hotwrench
Old 06-13-2013, 09:56 AM
cj06's Avatar
cj06
cj06 is offline
MY OPINION IS BELT DRIVEN IS THE BEST , EASIEST WAY AND MOST RELIABLE FOR ALL AROUND USAGE !
DUMP BOXES WORK GOOD FROM A PTO !
BIGGER TRUCKS IS WHERE I HAVE SEEN THE FRONT CRANK MOUNTED PUMPS MOSTLY ON CEMENT TRUCKS !
TX460Bronco
05-01-2013 10:54 PM
galute
04-01-2010 10:34 AM
73 ford guy
02-26-2009 06:40 PM
95F350_460
11-20-2008 12:01 PM
cujo8
15
06-10-2006 08:42 PM
Quick Reply: hydraulic pumps
