Ford l9000 flasher
turn signal problem L9000 help
Greetings This is my first post. I have an old 91 L9000 - right turn signals quit. Could the flasher cancel only one side? I took the switch apart, and I have juice to one side only. When I try to jump a hot wire to the other side it heats up and shorts. Im thinking the flasher, but not sure.
Thanks also, any place where i can get parts??
Ron
Ron
No.
No.
F3HZ-13350-A (replaced D3TZ-13350-A & D4TZ-13350-A) .. T/S Flasher / Available from Ford & auto parts stores.
MSRP: $59.71 // autonationfordwhitebearlake.com (MN) online price: $36.12.
Misc: 1973/90's B/C/F/L/LN/LNT/LT/LTL/LTS500 and larger series trucks.
Note: L9000 is a L900 w/a diesel engine.
Thank you very much. I have not found the flasher yet but Im getting ready to make the dive under the dash. I took the T/S switch apart and found something strange.... I had constant hot to the yellow wire, which feed the long soldered buss, and when I turned left, the gray wire and the yellow flashed. But the other side was dead. When I ran juice to it, nothing. So I guess the search is on. THanks again.
OK, I tried to reply but it disappeared. so I'll try again.
THanks Destroked. I found the flasher- a tiny auto flasher that someone apparently installed. But it clicks when left signal is turned on...but not the right. So, I figure the problem has to be upstream from the flasher. So...I'm going to replace the swtich.
Thanks again
Ron Z
Thanks again
Ron Z
riskman
05-28-2010 08:43 AM
1974Ranger
02-01-2010 11:22 PM
