Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Super Charger/gauge cluster swap< HELP
Old 05-12-2013, 08:28 PM
99F250LDEXTCAB's Avatar
99F250LDEXTCAB
99F250LDEXTCAB is offline
i bought a smashed lightning for parts and swaped out the supercharger to my f250 and i swaped out the cluster to use the factory boost gauge and the pats is not letting me start, can any one tell me how to either swap the pats module in the clusters or what i live over 4 hours to a city and deffinitly cant have it towed that far.
Old 05-13-2013, 04:03 AM
Pili's Avatar
Pili
Pili is offline
you need to use the lightning ecu along with the gauge cluster for the pats to work properly. Your only other option is to get with a lightning turner and have them turn off the pats in the tune
Old 05-13-2013, 05:33 AM
99F250LDEXTCAB
ecu location
ok then where is the ecu located in these rigs? and it will work for me then if i swap the ecu's?
Old 05-13-2013, 05:39 AM
99F250LDEXTCAB
key
also wouldnt i need to use the key from the lightning if im using the cluster and ecu?
Old 05-13-2013, 04:37 PM
Pili's Avatar
Pili
Pili is offline
I'm not sure where exactly the ecu is. I want to say passenger side kick panel. And yes the ignition would need to be used as well. But like i said earlier when you go to get tuned just get the pats turned off.
Also while im thinking about it. a n/a 5.4 has a slightly higher compression ratio then a boosted 5.4. Its not much but i would defently make sure the tune is stop on or you will be doing the window mod.
Old 05-13-2013, 05:30 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
I know you have a 250, but this is what is needed to convert a N/A F150 to run a Lightning S/C. http://www.madenterprise.com/scparts.htm
Mike has it down pat and is very helpful and I bet he wouldn't mind answering any questions you have.
Stewart
LeneliTanker
1999 to 2016 Super Duty
02-13-2015 05:34 PM
George diB
1997 - 2003 F150
16
11-27-2004 10:48 PM
mikey67156
09-01-2003 10:48 PM
Quick Reply: Super Charger/gauge cluster swap< HELP
