Cab lights
Old 05-08-2013, 11:25 AM
Shwan_89HD's Avatar
Shwan_89HD
Shwan_89HD is offline
Cab lights
Shopping for cab lights for my 89 F250, and im undecided as which cab lights to get. Its between 49-3705 or 49-3700 on this LMC link Truck Parts and Truck Accessories Let me know what yall think and which one should i get. Pics of yalls trucks would be nice too. Thanks!
Old 05-08-2013, 02:31 PM
gasman6674's Avatar
gasman6674
gasman6674 is offline
The 3700 is oem style, Truck-Lite made them for Ford you might check them out for comparsion.
I bought these to replace the cracked ones on my truck
25760y from amazon
Old 05-08-2013, 02:51 PM
Shwan_89HD's Avatar
Shwan_89HD
25760y from amazon
Ya i knew they were OEM which is why i kind of want them, but i also like the look of the other one a bit better. However i havent seen those cab lights on 80-91 F series so idk how it would look
Old 05-08-2013, 08:30 PM
IDIDieselJohn's Avatar
IDIDieselJohn
IDIDieselJohn is offline
Heres one with them lights!
Old 05-08-2013, 10:14 PM
BigBlockF350's Avatar
BigBlockF350
BigBlockF350 is offline
I think I'm going to put the same ones that the newer trucks use onto my '88.
Like this Like this
Old 05-08-2013, 10:32 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
If you decide on the factory route, get a harness form a salvage yard, buy these:
Cab Marker Light Yellow, 25760Y, Truck-Lite - Ryder Fleet Products
and read this:
https://www.ford-trucks.com/forums/1...-lights-2.html
Old 05-10-2013, 01:39 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
If i were to ever put cab lights on one of our trucks, it would have to be the OEM looking ones or none at all.
Old 05-10-2013, 08:06 AM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
I agree, for me it would be OEM style or none...yes I like LEDs but I don't care for the "sleak" design style of the LED units...our trucks are kind of boxy looking so I want the lights that look best with the body style...
Old 05-10-2013, 11:48 AM
Shwan_89HD's Avatar
Shwan_89HD
Ya im most likely gonna go with the OEM cab lights
Old 05-10-2013, 01:26 PM
damarble's Avatar
damarble
damarble is offline
Originally Posted by BigBlockF350
I think I'm going to put the same ones that the newer trucks use onto my '88. Like this
I salvaged a set of those at the junkyard once and recently mocked them up. They look good, BUT, if you already have lights they will not cover the factory holes. Debating welding them up or sticking with the old style if I can get them in clear or smoked.
Old 05-11-2013, 08:14 AM
Jaime74656's Avatar
Jaime74656
to be honest, my whole thoughts on the cab lights is if they came from the factory OEM great, but if the truck did not come with them its just better to leave them off, as you could possibly be looking at potental leaks in the future, but if any go on its always good to go OEM with the proper style/set that would be for your year truck.
Old 05-11-2013, 11:22 AM
IDIDieselJohn
^^^ If they are properly installed, they will never leak!
Old 05-11-2013, 04:38 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Just a FYI. the Superduty(99-current) cab lights, have STUDS that come out the bottom. which means you need to access them from the BOTTOM. The problem is, the OBS trucks have a DOUBLE layer inner headliner on a reg cab/bronco. That makes it IMPOSSIBLE to access the studs to put nuts on unless you drill MORE holes in the inner roof. The supercab and crew cab have a 8" wide inner roof piece just under where the cab lights mount and make it a real BIOTCH to access the nuts.
Just something to think about
wvhillbilly79
01-26-2012 12:08 PM
jgavac
04-17-2011 07:55 PM
Muddedprairie
2004 - 2008 F150
02-03-2009 02:29 PM
skidrow01
1997 - 2003 F150
11-12-2008 05:49 PM
Quick Reply: Cab lights
