Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1957 f800 big job fire truck
Old 05-06-2013, 09:10 PM
Matthew Graham's Avatar
Matthew Graham
Matthew Graham is offline
I am a volunteer fire fighter I had just purchased out fire departments antique fire truck I'm looking for parts to restore the truck to its former glory dose anyone know where I can find parts I have called around to local ford dealers and I just get laughed at and I can't seem to find anything on eBay or craigslist
Old 05-06-2013, 11:11 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Welcome to FTE.
You may be able to find some parts at certain dealers. Numberdummy has a way of finding obsolete parts.
Post your VIN and all the info off warranty/data plate on the door (or is it in the glove box....?)
If you have a Superduty V8, you will find it tough sledding to find parts, but not impossible.
Does it run, shift and drive OK?
Is this a paint and polish job or are you in trouble drive train wise?
Old 05-06-2013, 11:47 PM
Matthew Graham
Yes it runs and drives fine it will need a new slave cylinder have to bleed the clutch every time I wanna take it for a ride. The bracket for the emergency brake had just broke the other day it is a cast aluminum piece right under the cab right now I can give you the vin I have title in hand will go out and get the rest of the info tomorrow before I go to work the vin is f80f7h11241
Old 05-07-2013, 07:45 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by Matthew Graham
It runs and drives fine, it will need a new slave cylinder, have to bleed the clutch every time I wanna take it for a ride.
VIN: F80F7H11241
Welcome to FTE
F80 = F800.
F = 332 4V (Lincoln derived Y block).
7 = 1957.
H = Lorain OH Assembly Plant.
11241 = 1957 Numerical Sequence of Assembly, the trucks specific serial number.
When asking for parts, it makes it easier for all concerned if you mention where you're located.
C5TZ-7A508-D (replaced B7C-7553-A & C3TZ-7A508-D) .. Clutch Slave Cylinder / Obsolete
1957/60 F100/950 / 1961/62 F700/850 / 1963/64 F800 / 1965/69 F800/1100.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
MUSTANG'S ETC in Van Nuys CA has 1 = 818-787-7634.
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
C3TZ-7A508-D =
WESLEY OBSOLETE PARTS has 3.
B7C-7560-A .. Clutch Slave Cylinder Repair Kit / Obsolete
1957/59 F100/950.
GREEN SALES CO. in Cincinnati OH has 9 = 800-543-4959.
KINSEL L/M in Beaumont TX has 18 = 800-816-2894.
Many more sources, but without knowing where you live, I'm not gonna list them all.
Old 07-02-2013, 06:22 PM
Matthew Graham
looking for more parts
My bracket for my emergency brake bracket that goes towards the rear end that is cast has broken into 3 pieces and i Can not find it anywhere can anyone locate it for me the org part number was 2654
Old 07-03-2013, 12:53 PM
3414's Avatar
3414
3414 is offline
You will probably not find a new one. For used, look for salvage yards that have similar size and vintage trucks. You can always remove the old bracket, piece it together, take dimensions, and fabricate a replacement from steel bar. Not "original", but it will function as original.
Old 07-05-2013, 05:25 AM
big job's Avatar
big job
big job is offline
clutch slave cyl. napa around 80 bucks
Old 06-07-2014, 01:16 PM
Matthew Graham
I'm looking for a master cylinder any ideas where I can find 1
Old 06-12-2014, 07:56 AM
3414's Avatar
3414
3414 is offline
I have found master cylinders at NAPA stores that handle truck parts. Wagner was a common brand and often a Wagner number was cast on the outside, sometimes that can be used to get an exact replacement. A NAPA store with the old paper catalogs can be very helpful.
Old 07-11-2014, 06:29 AM
pilot31's Avatar
pilot31
pilot31 is offline
My 1952 F-8 master cylinder took a dorman part# m2657. Not sure if your truck is that same one or not, my book doesn't go that far. Just as a side note, the wheel cyl front are dorman part # w949. Sorry can't help on the slave cyl.
Old 07-12-2014, 03:44 PM
NumberDummy
1957 F800: I'm looking for a master cylinder, any ideas where I can find 1?
Brake master cylinder or clutch master cylinder?
Old 07-13-2014, 08:59 PM
pilot31's Avatar
pilot31
pilot31 is offline
Brake Master cylinder, not a slave cylinder for a clutch.
Old 07-15-2014, 10:35 AM
NumberDummy
Hydraulic clutch uses a master cylinder and a slave cylinder. OP has a 1957 F800 with a hydraulic clutch.
OP in post 8 asked for a master cylinder, but did not define if the master cylinder is for the brakes or the clutch.
Since the OP previously asked (post 3) for the slave cylinder, one could suppose he now wants the clutch master cylinder:
B8TZ-7A508-A .. Hydraulic Clutch Master Cylinder / Obsolete
Applications: 1957/60 F100/1100.
Old 08-11-2014, 08:46 PM
John R. Thomas's Avatar
John R. Thomas
John R. Thomas is offline
Post pictures of your rig. Who built it? pump mfg. GPM? booster tank? History,
Cared for? etc
We owned a 55 Peter Pirsch open cab custom built for the Waukesha FD.
Waukesha gas 6, 5-speed spicer, Ross cam & roller steering, Hale 1000gpm pump,
500 gal. booster tank. Front line for 20 years and best reserve for 15 more.
Never parked outside / unprotected. I equipped it as it was in service.
I can send a picture from jrtljt031648@att.net
farmfords
Large Truck
10-12-2016 11:32 AM
brechlrl
Large Truck
06-10-2016 09:24 PM
INTREPER
Large Truck
02-06-2013 10:59 PM
mthompson41
09-11-2012 04:48 PM
GleanerFord
06-02-2011 01:10 PM
Quick Reply: 1957 f800 big job fire truck
