1960 F100 Disc Brake Kit Question...
Old 05-03-2013, 06:34 PM
deyomatic's Avatar
deyomatic
deyomatic is offline
I just installed the ECI Disc Brake Kit on the front of my '60 F100. Ran into a bunch of issues that were all answered AFTER THE FACT, by a "how to" here on this site. (I should have checked here first!)
Installation of Manual or Power Brakes Disc Brakes in a 1957 - 1964 F100 .: Articles
Step 3 says to check the location of the king pin retaining nut and says it needs to be on the front side of the axle. My buddy started the installation on the passenger side (he moved the nut) while I worked on the master cylinder adapter and bench bled it. I felt left out of the fun, so I just took over on the driver's side with his instruction, and he forgot that part. Now, the whole kit is installed, and this nut on the drivers side wasn't moved. It has obviously rubbed on the new caliper bracket because it's shiny now.
My question: Does everything need to come off again, or can I just move the front wheels to one side or another to gain access, as long as I don't move the spindle when this pin is out?
Also, how does the pin come out? Hit it with a hammer a few times and punch it out the other end?
Thanks.
Old 05-03-2013, 07:21 PM
spurredon's Avatar
spurredon
spurredon is offline
Seems to me they are tapered and yes, tap them out backward from the threads.
Old 05-04-2013, 04:08 AM
oldebrush's Avatar
oldebrush
oldebrush is offline
Right Spur, but may I suggest to leave the nut on, just fully covering the treads to begin pounding the pin out. After breaking it loose, remove the nut and using a correct sixe drift finish driving the tapered bolt/pin out. You will notice some flutes in the OD of the pin. These will have to make mating flutes in the opposite side of the axel when driving the pin back in. The nut may not have thread strength enough to pull the pin into position, so as you tighten the nut with the lock washer behind it, tap the pin in to follow the nut. Should work fine that way.
Old 05-04-2013, 06:24 AM
deyomatic's Avatar
deyomatic
Alright, I guess I'll jump in there when I get the time.
Do I need to take the caliper, rotor, and bracket off, now, or can I just crank the wheel so that I have access to the back nut and do it with that stuff in place? The bracket doesn't interfere with anything on the front of the axle, I know that it says not to move the spindle with the pin out, but does the spindle need to be perpendicular when I take it out and replace it in the opposite direction?
Old 05-04-2013, 06:30 PM
spurredon's Avatar
spurredon
The spindle won't care which way it is turned, just leave it in the same posistion for the whole job!
Old 05-04-2013, 08:30 PM
deyomatic's Avatar
deyomatic
Good to hear. I figure I'll only jack up that one side, so that the passenger tire's friction on the floor will help to hold the driver's side spindle from moving.
Thanks.
Old 05-05-2013, 08:05 PM
deyomatic's Avatar
deyomatic
Thanks to all for the assistance on this. I did it this morning. It came out A LOT easier than I thought it was going to, but took A LOT more persuasion to get it back in than I thought it was going to.
Old 05-06-2013, 09:09 PM
spurredon's Avatar
spurredon
Glad it worked out for you.
Old 05-10-2013, 08:56 AM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Over all, how would you rate this mod in terms of difficulty? I thought about doing this but decided to tackle it later. I know it would be easier now with the front half of the truck off, but not gonna duit, too poor
Old 05-10-2013, 03:19 PM
Walston's Avatar
Walston
Walston is online now
1 easy, 10 hard. This job is a 3. IMHO.
ReFlectiveMan
02-18-2012 11:04 PM
todd jo
10-20-2010 07:58 PM
bsteele52
01-05-2010 12:38 AM
bgriffin09
03-08-2007 10:54 PM
galanthias
03-17-2005 11:03 PM
Quick Reply: 1960 F100 Disc Brake Kit Question...
