1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How much weight can my truck really pull?
Old 04-29-2013, 07:37 PM
83FordPdx's Avatar
83FordPdx
83FordPdx is offline
So I am looking at a new travel trailer. And I have heard conflicting information on how much my truck can actually pull.
Here is my truck info.
2004 F-250 Super Cab Super Duty. 5.4L 4x4
The trailer I am looking at has a dry of 5800lbs.
Thanks for the help.
Old 04-29-2013, 07:42 PM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
Your towing guide:
You should be good for at least 7200 lbs.
Old 04-29-2013, 07:43 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Here's a link to the 2004 Towing Guide:
https://www.fleet.ford.com/showroom/...r_F250_350.pdf
A lot is dependent upon the axle ratio because there's a 1,500 difference between the 3.73 and 4.10.
Old 04-29-2013, 07:52 PM
83FordPdx's Avatar
83FordPdx
I have the 3.73 ratio
So from reading the guide I am getting 7,100 lbs
Old 04-29-2013, 07:58 PM
senix's Avatar
senix
senix is offline
It should pull it fine. Remember alot of the power is going to be made as the motor revs. It is ok to let it sing a bit.
Old 04-29-2013, 10:33 PM
Quad Racer's Avatar
Quad Racer
Quad Racer is offline
Like Scott said it'll pull it no problem.
You may consider a couple upgrades to your truck to prepare it for the task?
I consider how often I'd tow and the terrain.
Old 04-30-2013, 05:05 AM
drey04's Avatar
drey04
drey04 is offline
You'll be just fine. My dad's 30 footer weighs 7200 dry and 9300 loaded and I drag it around easily with my truck. Not gonna win any races, but she pulls strong.
Old 04-30-2013, 07:44 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
dry weight is a meaningless number - go by gvwr which will be a lost closer to what you will be towing... and then it's still a guide until YOU load it up and spend $10 at a cat scale to find out the real weights...
we can't know how many pairs of shoes your wife has to bring along for 'roughing it'
also, you didn't state if yours is an
auto or manual,
crew cab, supercab, or regular cab and
does it have the stock tires on it ????
and ASSUMING it's an auto and supercab and tow behind and not a 5th wheel...
To really get it right, all that makes a difference in what you can actually pull !
gcwr and rear axle weight rating are important numbers too..
good luck !
bottom line we're giving you ballpark answers until all the parameters are known...
if you say 7100 then it must be an automatic supercab f-250 4x4 3.73 5.4L ....
wiredgeorge
09-09-2017 06:14 PM
sscheitel
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
06-22-2017 11:59 PM
COBRA028
1997 - 2003 F150
04-02-2014 02:28 PM
whitetail
2009 - 2014 F150
15
02-20-2012 09:46 AM
ggwash21
2004 - 2008 F150
04-26-2009 10:18 AM
Quick Reply: How much weight can my truck really pull?
