6.2L V8 Discuss the 6.2L V8
Remote start
Old 04-28-2013, 07:58 PM
albertatyke's Avatar
albertatyke
albertatyke is offline
Remote start
What does people think to the remote start that comes with Lariat ultimate package?
What sort of distance does it work from, do the heated seats work with it??
Old 04-29-2013, 05:34 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
I love mine, wouldn't go through a winter without one. Not sure on the distance, maybe a few hundred feet in the open and works from anywhere in my house if the truck's in the driveway.
Yes it works with the heated seats, at least the '11/'12's do. I'm sure the new system with the MFT works similarly. If the temps are below 32, it'll kick all the heaters/defrost on when the truck warms up, above I think 85 or something (can't remember the magic # there) and it'll do the opposite, kick the AC/cooled seats on.
Old 04-29-2013, 08:33 AM
Amelio's Avatar
Amelio
Amelio is offline
love mine also....I have activated it a few hundred feet in a parking lot......it has acted funny a few times and not worked...brought it to the dealer they could not duplicate it....it only did it once.
its one of my favorite features!
Old 04-29-2013, 11:12 AM
albertatyke
thanks for the replies
I have now completed my first week of waiting for my new toy only another 7'ish to go this is really hard.......I may need therapy
Old 04-29-2013, 01:02 PM
socapots's Avatar
socapots
socapots is offline
I have it on my 2011, Its ok. But not great. Works good from the house to the truck when its parked out front.. I wish you could start more then 2wice (i know thats alot but sometimes its needed)
Does not seem to work so well when im at work. Maybe its just the surroundings. Not sure.
If i had to do it over i would probably just get an aftermarket unit instead. Double the cost and another fob on your key chain would be the downfalls. At least to me.
Old 04-29-2013, 04:21 PM
RAPR's Avatar
RAPR
RAPR is offline
great feature. I've had this feature on a few vehicles before and this one has the most distance/wall penetration I've messed with so far.
Old 04-30-2013, 12:01 PM
kerm7807's Avatar
kerm7807
kerm7807 is offline
Mine acted "funny" a few times too. It would single beep and not work, and then a couple times the truck double beeped and wouldn't start. The problem was intermittent and then the I found out the problem was most likely low voltage. The battery finally had a melt down at just a year old. I replaced it with a much better battery and have never had a problem since. The distance on the remote start is probably only 2-300 ft though.
Old 05-02-2013, 08:37 AM
Amelio's Avatar
Amelio
Amelio is offline
I was leaving the gym last night I was walking towards my truck which was on the other side of the building I was going around.....the truck was probably 150-200 away and on the other side of the building so it was not in sight......I hit the button for the hell of it and it worked! I was pretty shocked being that the truck was no in line of sight.....I think its an excellent system especially for a factory unit.
Old 05-02-2013, 09:00 PM
cparks's Avatar
cparks
cparks is offline
I have it on my 2012 Raptor. I was surprised this winter when I started it in my office. I thought what the heck would try which was a bit away from the truck and did not even know it was running until I went outside. Works good for me.
Old 05-03-2013, 06:29 AM
2000silverbullet
Not sure if this is compatible with the 13's, but here's a bi-directional kit that'll tell you when it's started (for times when you can't see the truck).
https://www.ford-trucks.com/forums/1...-and-play.html
Old 01-03-2014, 07:35 AM
Fastfwd's Avatar
Fastfwd
Fastfwd is offline
Is this the OEM one or an aftermarket? Mine works from about 50' tops and probably less. Good enough to start from within my house.
Old 01-03-2014, 08:05 AM
JimRay's Avatar
JimRay
JimRay is offline
Mine won't start if its in the detached garage, but I believe that to be more about the construction of the garage and it being a metal building. Seems to work fine in the open from a couple hundred feet.
Old 01-03-2014, 11:39 AM
Amelio's Avatar
Amelio
Amelio is offline
Mine is factory...... I use it almost every time especially when it's cold. When I get in its warmed up a bit.
Very nice feature..... Love it!
Old 01-03-2014, 04:24 PM
Hotrod70d's Avatar
Hotrod70d
Hotrod70d is offline
ebay has some that are plug and play about 8 connections. take about half hr to install some work more than a 1000 feet and there only about $150.
Old 01-04-2014, 12:15 AM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
I use mine almost all the time!! Absolutely love the feature...
IMHO...if using it often...the key fob battery takes a hit. I think my battery is on the low side already. At least in comparison to other vehicle key fobs.
Worth every penny!!
biz
Quick Reply: Remote start
