Tires ?
I didn't check your location but I only buy Michelin tires. If I were going with a set and keeping the truck I would go with either the LTX AT2 or the Goodyear Wrangler SR-A. The michelins will be good for about 70 to 90k depending on the power you are making, how much trailering you do and how much you rotate the tires. If money were no object I would go LTX AT2 and not look back. They will be a hair louder than the SR-A but are better off the concrete jungle.
nope personally there's only 4 small patches connect my *** to the road and I want them to be the best possible and on a light truck that's michelin or Goodyear unless you need something aggressive then I would go Nitto Terra Grappler or BFG AT/KOs and with the BFGs you'll need 6 to 7 tires to make a set of 4 balanced tires.
loaded question. what is your budget?
I love the Wrangler Silent Armour
and
I love the Firestone Destination A/T
both were excellent mid-range tires that I would buy again in a heartbeat. The Silent Armour looked beefier, but both had excellent wet/dry traction and they rate at the top of their category on Tirerack.com
and
285/55R20 would be close in size, about a 1/2 inch taller. Note that the 18" tires for some reason are 32.1 and the 20"s are just a hair under 32". Why I have no idea.
The LTX M/S2 is a great tire and will take care of you till somewhere between 80 and 100K miles. They last longer than the AT2 hands down but are not as aggressive.
