2005 F250 6.0 Turbo Diesel with hesitation...
I bought the 2005 F250 6.0 with 67,000 miles on it last March. It has given me gave me absolutely no problems until now. In the last 2 weeks I have had it plugged in when it was below 32 degrees outside. Otherwise, I just remote started it every morning and let it run for 20 minutes before I left. In the last 2 weeks, I have noticed the same problem whether it is morning, afternoon, or evening and it happens at different times. I will be at a standstill at a stop light, stop sign, or parked in my driveway when this occurs. Sometimes, and like I said, "sometimes", it will hesitate when I give it throttle. It will quickly respond after maybe a second, but the hesitation is still there. It only does this on occasion! I work for a Lucas Oil distributor, so in the winter I ran the "extreme diesel conditioner" through it with a tank of diesel about every other week. I also used the fuel-injector cleaner at every fill up. On "ONE" occasion, and like I said, "ONE" occasion, when it hesitated at a stoplight, I looked in the rearview mirror, and noticed a short burst of white smoke, and then it took off. It has not done that since. I took the EGR off and cleaned it and it seemed okay until 2 days later, then the same hesitation came back, but like I said, at times! I replaced the air filter and since then I have done nothing. I am now being told to check the coolant level in the resevoir. When I un-screwed the cap the cap, there was pressure in there and the fluid was about 1/4 inch low from the line. I was also told to check the filter on top of the block, but I have not gotten that far. Ford says it is the EGR cooler system and wants $2,400 to fix it if that is whats bad! I have "NO" check engine lights! Thoughts???
One more thing to check would be the FICM voltage, unless you have done this already.
Do yourself a favor and get some engine monitoring device on your truck asap and learn all the functions it has.
I am running an "Edge Insight", saved me some on the road headaches a couple of years ago in Las Vegas
Also maybe the moderators can move this to the 6.0 forum.
Good luck
Good luck
Come on over to the 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
and post the question again. You will get a better shot at a fix.
Sean
Sean
Last edited by powerstroke72; 04-09-2013 at 01:07 PM. Reason: Removed unnecessary info.
A tuner is not going to fix the problem.
Let see we can start with the FICM then move on to wrong filter dirty filters.
A dirty fuel filter will do this and also if he does not have the upgraded fuel
pressure regulator spring installed.
Sean
Sean
Last edited by powerstroke72; 04-09-2013 at 01:08 PM. Reason: Remove unnecessary info
We can get you through an EGR cooler replacement for a lot less that $2,400, with better parts than OEM if that's really the root cause.<filllllllllllllllllllllllll></filllllllllllllllllllllllll>
Last edited by texastech_diesel; 04-09-2013 at 01:38 PM. Reason: Made relevant again :-X22
The post from that person was removed.
That blue spring that you said you ordered regulates your fuel pressure, The problems you say you are having might be fuel pressure related. I say install the blue spring and see if anything changes with you issues.
rhillman75
1999 to 2016 Super Duty
10-28-2013 11:11 PM
HunerdProof1371
02-17-2013 07:54 AM
